LED everything
Discussion in 'Gen 2 Prius Accessories & Modifications' started by FCguy, Mar 22, 2013.
  1. Fore
    Fore Don't look back!
    494
    107
    I bought the cheap set off of eBay that were recommend here by another Prius Chat member. After 10 months they started to flicker. Replaced them and put the original bulbs back in. Tired of all this LED crap.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    True... I'm betting that the price reflects the brightness and quality...so maybe later I'll take the plunge. For now I'll happy with my super bright led interior lights.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    This is EXACTLY why GOOD LEDs cost! I know it's nice to save money, but spending wisely matters more!
    Justdidit likes this.
  4. 2007blueprius
    2007blueprius Member
    461
    30
    good point, however if you realy think about it, led's are not hat wise of a buy in the first place especialy the ones that cost, don't get me wrong I love the IDEEA I think it fits the prius better all arround, I just had a look at your thread, good work by the way, I'd also like to have something other than led acid for an auxiliary 12v but its not that feasable, not yet at least. guess I'm just bummed that the good stuff is ourageus, its a novelty thing, also if you realy take everything into acount like 50k hours rated, not sure how many incandescents youd go throu, or priuses for that matter
  5. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Wow the Sencart panels are cheaper ... too bad I didn't hear about them sooner.
  6. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    So I made a couple of videos about getting the back hatch off. A lot of people refer to the video of the guy in his dark garage blasting Metallica (IIRC). They are both a bit redunant ... I'm no Youtube video expert. I do think that they show how the panel is ACTUALLY removed.
    Video 1
    Video 2
  7. Johnny C
    Johnny C Member
    162
    Boston
    Anyone have some LED recommendations for the door lights?
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Pretty sure if you pick up some T10 168 White 5050 SMD leds or larger...You shouldn't be dissatisfied with the brightness.
    Been a while but pretty sure I used something like this...not same brand but similar. They were perfect because they were directional. Not shooting light where I didn't want it...but only on the ground where I need it.
  9. Johnny C
    Johnny C Member
    162
    Boston
    Thank you, Justdidit. Do you think this will work?
    4x 194 168 501 T10 9-SMD White 5050 LED Car Light Bulb : Amazon.com : Automotive
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
  11. Johnny C
    Johnny C Member
    162
    Boston
    That's an excellent point. Thank you again.
  12. FCguy
    FCguy Junior Member
    28
    Atlanta
    I
    Remember that light can and is reflected. When you can only aim X amount of LEDs in the direction you want due to size/placement restrictions you can still increase usable brightness by using additional LEDs to light up the housing ... especially if it is a reflector.
    However in this case the LEDs he posted are certainly a better choice as you are getting more pointed in the direction you desire and the housing in the door is not a reflecting type.
    However I think even better results can be had with SMD panel type lighting. Get out your micrometer and see if this will fit! (A better deal can be had from the supplier that a previous poster mentioned but I just wanted to put the idea out there in the short amount of time I had to write this post)
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    ^Agreed...if you can make it fit.
    Just cheaper here.
  14. Johnny C
    Johnny C Member
    162
    Boston
    Do you guys recommend the same thing for the trunk light?
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Sure. Usually those Sencart kits come with almost every connection type..
  16. Johnny C
    Johnny C Member
    162
    Boston
    The 3x4 LED arrangement just seems a bit large to fit in the truck light enclosure.
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
  18. PhilWray
    PhilWray Member
    82
    28
    Malaysia
  19. Johnny C
    Johnny C Member
    162
    Boston
