HID Headlight intermitently fails to start even after bulb replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tmorrowus, Mar 9, 2013.
  1. tmorrowus
    tmorrowus Member
    514
    Around 100k miles, my 2004 prius started failing to light the right headlight. It only happened every now and then, perhaps 5-10% of the time. It seems to fail more often in cold weather. I can always get it to light by turning headlights off and on a 2-4 times.
    I had luscious garage in San Francisco replace both bulbs with the ones I bought on amazon.com. I couldn't install them myself since it required more grip strength than I had to twist off the cover that had been in place about a decade.
    That seemed to help, but I still get intermittent failures where the right HID doesn't start sometimes. The left always works reliably.
    Obviously replacing the ballast should solve this, but that is expensive and I wonder if perhaps there is some connection that has developed a high resistance that could be solved by reseating. Any suggestions?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Which bulbs did you buy from Amazon? Brand, make and model? Were they being sold by Amazon itself or a 3rd party reseller there?
    As for obvious, don't know until we know the above.
  3. tmorrowus
    tmorrowus Member
    514
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Did you buy Philips D2R bulbs sold by Amazon or some other 3rd party listing on Amazon?
  5. tmorrowus
    tmorrowus Member
    514
    I bought them from amazon, not any other seller on amazon.
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I guess you could check the wiring and the connector before replacing the ballast. You could also swap bulbs from side to side to help see if it really is the ballast.
    How many miles are you at now, out of curiosity?
  7. tmorrowus
    tmorrowus Member
    514
    106k miles. Thanks for the suggestions and any others.
  8. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
