Water Pump Replacement @ 80k?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brynnflynn, Apr 9, 2013.
  1. Brynnflynn
    Brynnflynn New Member
    Hi everyone! I just wanted to start by saying how grateful I am that there is literally a forum for every topic on the Internet, because I need some help!
    I have a 2007 Prius that was given to me by my parents (VERY grateful!). This car was kept in tip top shape, and went to the dealership every single 5k interval for oil changes and the works. It hadn't had any major issues when it became my car at 45k miles. It had the HV Water Pump replaced under recall in 2011 at 51k.
    Now, at 80k miles, I'm trying to make sure I'm not getting fleeced by a dealership (they previously told my fiancé that his 20k Matrix needed to be completely replaced due to a rusting undercarriage, yeah). I took it in for a standard oil change, and was told that the water pump was leaking. I asked them to show it to me, and they were able to point to some pink coolant that looked like it splattered in the car. They quoted $336 to replace it.
    So, with all that information (which I hope helps!), I have a couple questions.
    1. Based on the info I was given and shown, and with the knowledge that the car has not been acting up in any way, is it reasonable that this could happen? Especially since it's had a water pump replaced under warranty already?
    2. Is the price reasonable?
    My mother is just worried (and I am as well) since our other two Priuses ('05 and '10 I believe) have had 0 problems. Zip, zero, nada, so I would like to make sure that I'm not being taken for a ride. I at least had the sense to laugh at their offer of $175 to replace the spark plugs; I'm going to do that myself.
    Thank you for any help! If it would help I will try to get a picture of the splatter tonight when I get home from work.
  2. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Check out this other recent thread...common problem...
    re: picture, we know about the bright pink salts. You can DIY cheaper if so inclined.
    Well I am one who procrastinated replacing the water pump, and right now holding tight at 120k miles. Mine leaked at one point around 70-80k miles. I realized the antifreeze fluid level was low, and bought a gallon of the special Toyota fluid, and filled up. Now not leaking.
    Many folks replaced these water pumps under extended warranty, but I did not have one.
    Read more: http://priuschat.com/threads/waterpump-replacement.124318/#ixzz2PyiJEam1
  3. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    I had the bright pink salts on the hood liner and on the pulley also.
    I bought my 2008 at 85k miles and it ran fine for 20k miles no leaks. Somewhere between 105k and 110k it emptied the overflow tank on the pulley and hood liner so I rinsed off the hood liner and the pulley and have driven 15k no further leaking.
    Thinking back a bit the problem could be caused by a sticky radiator cap blowoff valve which I inadvertently fixed when I took the cap off and I 'popped' both valves a couple of times to make sure they were not sticking.
    I wanted to see how much coolant was realy lost in addition to 1 tankfull.
    Please do not remove the cap when the system is HOT!!!!! heed the warnings
    I had a similar problem on a S10 Blazer at 5k miles that could not keep coolant in the cooling system, it would come pouring out at every hose to metal joint, but none at the coolant pump seal tho. Changing the cap fixed it until the coolant pump seal started dripping at 150k but that is another story.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    What is a radiator cap blow off valve and what are you "popping"?
  5. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Brynn,
    There are four different water Pumps in your Prius. The recall replaced the electric pump that circulates coolant for the Inverter (high voltage electronics) and transmission. The one that the dealer showed you is the mechanical coolant pump for the Internal Combustion Engine (ICE). Both of these loops need to have the coolant drained and refilled at 100k miles and then every 50k miles thereafter, but the dealer was supposed to have drained and refilled the Inverter loop as part of the recall, so plan accordingly. You can at least wait till 100k miles to replace the ICE coolant pump when you also drain and refill the coolant with Toyota Super Long Life (Pink, pre-diluted) coolant. I replaced my ICE coolant pump at 150k miles as a preventative measure.
    The other two coolant pumps are electrically operated, one for filling and emptying the ICE coolant "Thermos" that runs as you shut down and start up your Prius. The other circulates ICE coolant to the heater core when called for.
    One other coolant item that has caused some issues is the coolant valve that directs flow into and out of the thermos. If the ICE coolant loop is low you may get an OBDII code that says it is stuck. The coolant acts as a lubricant for this valve and may free it up when topped off.
    JeffD
    cwerdna likes this.
  6. TBurnham
    TBurnham Junior Member
    Wichita,KS
    I personally would say "NO" but this is the question that I would ask. Is the technician that said you need your ICE water pump replaced a CERTIFIED Prius mechanic? at my stealership - not all of them are certified to work on a Prius and do not have to be to: change oil/filter, tire care, etc.
    It is a known fact that Prius (ICE) water pumps weep pink fluid in their routine daily operation.
    I have personally been through this with my stealership more than once about them saying it needed the waterpump replaced but then when checked by a certified Prius mechanic at my stealership they said no it is within its normal weepage. I would follow jdenenberg's post and recommend replacement when you drain and fill the fluid at 100K as a preventive measure. (Personally my 2006 has turned the century mark several times and I have only replaced the ICE coolant pump once in the first 300K of its life.)
    Merkey likes this.
  7. ccdisce
    259
    187
    Stone Mtn GA USA
    The ICE Radiator 'Cap which is visible after the Radiator Cover is removed.
    The radiator 'cap' is realy a cap plus a sping loaded valve to let the system pressurize when it heats up eventually routing the excess fluid to the over flow tank (which is open to the atmosphere) plus another valve within the larger valve that lets fluid back into the radiator from the overflow tank when it cools.
    The overflow tank in a Prius does not need to be pressurized thank gooodness ( yes I have had to change them in a previous VW and Volvos. A well working radiator 'cap' prevents the hoses and radiator cores from collapsing/cracking and leaking.
    2009Prius likes this.
  8. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    I cannot argue with waiting until 100K to replace the pump with the coolant change, as long as the OP checks the coolant level frequently and remains on the lookout for active leakage. Most likely there will not be a major increase in leakage, but it has happened.
  9. richard schumacher
    7,664
    1,046
    United States
    I replaced mine when it started leaking at 70K because I didn't want to have to watch it and worry over it.
    edthefox5 likes this.
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Wrong car for the wait and see on a ICE pump. There's no temp gauge and by the time the CEL TEMP gauge activates its way past overheat.
    The engine has an aluminum head and does not appreciate any overheating. $
    So thats $200 for a new pump chasing $2000. for a new motor.
  11. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    I was wondering, the Prii are known for their water pump issues. Would it be a good idea to put some water pump lubricator in the radiator? I would imagine the Toyota rad coolant is already lubricated, but would there be any problem with adding some aftermarket radiator/water pump lubricating fluid as extra protection?
  12. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I would agree with Hobbit (at the bottom of the linked page), that the belt on these is too tight, and could lead to premature failure.
    100K maint - 2
    I backed my tension off a bit, and it does not slip, and works normally after a year.
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    OK really dumb question: how do I open the cap? I unscrewed it less than a turn and it loosened but still couldn't be removed easily. Since the cap is thin sheet metal and the tube is plastic I am afraid to yank on it.
  14. Patrick Wong
    18,210
    6,511
    1. Wait for the radiator cap to be cool to the touch.
    2. Rotate the cap counter clockwise until it hits the stop, then pull the cap up. It should not be difficult to remove.
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Yes thats a good idea. I have been using this stuff for a very long time and never any problem with my cooling system in any car. In fact I use a bottle in the Inverter Coolant tank also (same color) and it stopped the aluminum dry white powder residue on the cap. Found in most auto parts stores:
    Red Line Synthetic Oil - WaterWetter® Coolant Additives - WaterWetter®
  16. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    The cap is under the black plastic cover right? On mine by now the near-by plastic screw is missing so I just lift the plastic a little and reach under and turn the cap and it lifts off.
  17. 2009Prius
    2,705
    512
    63
    Thank you for the precise instructions as always! I did let it cool overnight. I will try pull harder next time.
    Yes I removed the plastic cover. I probably wasn't lifting hard enough. Thanks!
