Spark Plugs: Dielectric Grease and Anti-Seize Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Apr 11, 2013.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I've heard arguments for and against the use of anti-seize on the threads of spark plugs and I just can't decide which direction to go. This will be my first time changing the factory plugs. Does anti-seize come on the plugs from the factory? How much (size) is usually applied to the threads?
    Does anyone use dielectric (silicone) grease on the rubber boot of the plug wires? Does the grease get applied to the just the rubber boot or can you apply it to the ceramic part of the plug as well? Amount?
  2. toyotechwv
    toyotechwv Toyota Technician
    474
    252
    Princeton, WV
    Never seen a seized plug in a Toyota in 12 years and with the coil on plug design there isn't much need for dielectric grease. Won't hurt anything though if you decide to use them.
    SPH-D710 ? 2
    mtbiker53 likes this.
  3. Mendel Leisk
    41,889
    I don't think the dielectric grease on boot matters much, one way or the other. Regarding anti-sieze compound on the threads, I'm not so sure.
    If you look at torque guideline tables, there's usually multiple values given: one for clean threads, and others, invariably lower, for greased threads, depending on what's used. If a torque value is for dry threads, and you liberally oil or grease the threads and then torque them to that value, you are stressing the bolt or sparkplug somewhat more, I'd think.
    What do I do? Apply the anti-sieze, but extremely sparingly. Maybe just get some on a cloth, wipe most off, then wrap it around the thread zone and twist it a bit.
  4. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    It comes from the factory without grease. Its not broken, so why do you insist on fixing it with grease?
    Grease can melt and go places where you don't want it. Grease can also trap grit and end up grinding away precision fittings.
    Unless an application absolutely needs grease, don't use it! Sounds like you have a bit to learn about grease still...
    Galaxy Nexus ? 2
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You should find out what dielectric grease is and what he is thinking about doing with it before you go all expert on us.
    edthefox5 likes this.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I agree with you, but done right no harm done. The done right part is don't get any anti-seize on the spark plug electrode or ceramic on the engine end of the plug. The compounds in anti-seize can really mess up the sparking function of the plug.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  8. Baronbeck
    Baronbeck New Member
    maestro8Nouveau Member
    Feb 19, 2012
    453
    79
    nor cal
    Your Vehicle Year:
    He is not the only one!!!.​
    1. You do not fix things with grease - you protect them.​
    2. Most anti-seizes are made with bentone grease which as most people know is "non-melt"​
  9. maestro8
    471
    109
    nor cal
    Ok, tell me what I know and don't know, stranger. Then I'll tell you what's in my garage and how many hundreds of hours I've spent working on them...
  10. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I don't think I'll be using anti-seize as the NGK plugs I bought specifically state not to. They have a nickel coating on the threads that serves the same purpose as anti-seize compound.
    DROID RAZR ? 2
