Hybrid System Overheat
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WilMent, Apr 12, 2013.
  1. WilMent
    WilMent diacritic
    369
    149
    New York
    I received "Hybrid System Overheat" warning light on a 10 mile drive last night @ 45 degrees F. I was 2 miles away from home so I drove slowly after I stopped for 15 minutes. When I got home and restarted the car, "Check Hybrid System" light is on. I've try to cycle it 3+ times and the warning light remained. This morning the light was still there so I brought it to the dealers, hopefully nothing is seriously wrong. My baby only has 3k miles on it:cry:
    matt b. likes this.
  2. gliderman
    gliderman Active Member
    751
    225
    Well, at least its still under warranty. Let us know what they say.
  3. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    This is usually indicates a lack of coolant circulation in the Inverter coolant loop. Either the Inverter coolant pump has failed or there is air in the coolant loop and the pump has lost its priming fluid. If you put your Prius in "Ready" mode (In Park) and look at the coolant reservoir, you should see turbulence if the coolant is flowing.
    JeffD
    WilMent likes this.
  4. WilMent
    WilMent diacritic
    369
    149
    New York
    I see, that doesn't sound too bad I guess. I hope they can fix it soon. I dropped it off at 7am, still no call at almost 2
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yikes, doesn't sound good. I am sure they will fix it up right though...
  6. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Any updates?
  7. mnsweeps
    mnsweeps Member
    108
    Los Angeles CA
    any update? It would be interesting to know the cause..
  8. WilMent
    WilMent diacritic
    369
    149
    New York
    They took the front apart and found a dent on the radiator. Coolant leak, replacement part comes in Tuesday. Hopefully can get it back same day. For now, I am getting spoiled by the loaner PIP:)
    JMD likes this.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    are they going to cover that?
  10. WilMent
    WilMent diacritic
    369
    149
    New York
    Yes, they said there is no way to know if I got it with the damage or not. So they will just bill Toyota for defective parts. I didn't even buy the car from them, I will be doing my services there from now on :) Thanks Toyota of Olympia.
    JMD, ralleia, F8L and 1 other person like this.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Wow! Thats Great! :D
  12. wheelsup
    wheelsup Member
    105
    Raleigh, NC
    That's interesting, you'd think there would be a low coolant indication like most cars have. Maybe the "overheat" is the indication lol.
    JMD likes this.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, count your blessings, there have been a few members that had similar situations and the dealer wouldn't cover it.
  14. WilMent
    WilMent diacritic
    369
    149
    New York
    This Prius sure knew how to give me a heart attack:D
    Yeah, I got pretty lucky:) That sucks for the other members, this is the first time something like this happened to me... what a lucky little rock!
  15. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    One of the first things that bugged be after I picked up my Prius is that there is no coolant temperature gauge. It was especially worrisome since when we drove it home we were going to be climbing a lot of hills through Wyoming and the Black Hills region of South Dakota.
    I still don't like the lack of these basic gauges, but others on the board have recommended the scangauge device which adds a lot more monitoring data to your ride.
    WilMent likes this.
  16. Ursoboostd
    Ursoboostd New Member
    24
    Florence, Ky
    Pretty impressive. Sounds like you found a good dealer.
  17. WilMent
    WilMent diacritic
    369
    149
    New York
    I have the eco-route with my Garmin and the temp was normal @ 190F when I first pulled over. But I am glad the car is smart enough to tell me something was wrong before serious damages happened.
    They are a smaller dealer, no fancy waiting area, espresso bar, or loaner IPAD. But, service is all that matters. I will be going there from now on:)
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    differt coolant loop.
    WilMent likes this.
  19. WilMent
    WilMent diacritic
    369
    149
    New York
    I'm such a noob, I keep on forgetting I have a hybrid now:ROFLMAO: even the tech told me yesterday.... in one ear out the other :notworthy:
    I am checking out front mesh grills now. Do you guys think debris usually comes in the front or bounce from the bottom? I know they are totally random but I think the grill might help... + it looks pretty nice:D Would I have problems with air flow? It doesn't get too hot around here.
    spiderman likes this.
  20. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It is usually the AC condenser that get hurt by a stone since it is in front of the radiator (mine was). The mesh may protect that as well.
    JeffD
