jump terminals on a 2013 prius c (under the hood) There or Not
Discussion in 'Prius c Main Forum' started by john roman, Apr 9, 2013.
  1. john roman
    john roman Junior Member
    35
    I think it was 1/12, but its a 2013 the plate on the door jam it says 1/13.
  2. john roman
    35
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    How can you have a production date of 1/12 but it be a 2013 model?...
  4. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    Good question, take a pic of the production date.
    SPH-D710 ? 2
  5. john roman
    35
    i was just guessing as to 1/12, but the door jam says 1/13 on it
    ztanos likes this.
  6. john roman
    35
    and all the papers say 2013 model ( sticker, title, pink slip)
  7. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    I posted this before, but, since this seems to be a mystery, my 2013 C2's plate says my car was made 12/12 and it also does not have the under the hood terminals. Also thanks to the person who posted the video on jumping a Prius C as this is the way I'll have to do it if the need ever arises. This forum is really great. I continue to go through all that it contains and new even though I'm an old dog I'm learning new things about this great little car.
  8. john roman
    35
    Thiis is my plate
  9. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i need to go look in my C1 to see if the jump cables are there. hopefully they are
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It doesn't "look" too hard to add the jump attachment. I wonder if this is something Toyota will sell later. Or maybe the cable gauge isn't thick enough on the 2012.
  11. frodoz737
    frodoz737 Top Wrench
    4,790
    2,557
    33
    I'm willing to guess Dealer feedback had something to do with this effectivity change. They seem to always have the charger hooked up to a new Prius in the showroom. But what do I know?
  12. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Picture or link is missing.
  13. toyotechwv
    474
    254
    Princeton, WV
    OK guys, checked with our parts department. It shows 2 different relay blocks for 2013 C's, one is for up to 12/12 production, the other is for after 12/12 production. Apparently Toyota snuck it into the '13's starting with the C's made in '13. Part number for the later one which includes the jump terminal is 82620-52091 and it's $47. This block just pops out of the fuse box housing so it would be an easy swap.
    frodoz737 likes this.
  14. frodoz737
    4,790
    2,557
    33
  15. john roman
    35
    Id like to thank you I called toyota and I subbmitted a claim to have it inspected, and get the fuse box w
  16. john roman
    35
  17. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    swappable with the 2012 prius c?
  18. toyotechwv
    474
    254
    Princeton, WV
    Don't see why it wouldn't be.
    SPH-D710 ? 2
  19. B2FiNiTY
    979
    227
    It would seem that additional wiring would be needed? Or does it simply drop in and use existing wiring?
    If it's just plug and play, this could be a nice upgrade to existing 2012s.
    ztanos likes this.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    $47 for such a great ease of use would be worth it.
