Scantool to replace brake fluid
Discussion in 'Gen 2 Prius Technical Discussion' started by alexeft, Apr 16, 2013.
  1. alexeft
    alexeft Member
    142
    24
    Greece
    Hi all. Is there a scan tool that is able to replace the brake fluid of a gen II prius? Preferably not a high price tool.
    Thanks! :)
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    I want one that will replace the gas. ;)
  3. alexeft
    alexeft Member
    142
    24
    Greece
    Hmmmm, exactly my thought today!!! I want a prius that runs on pure air alone!!! :p
  4. alexeft
    alexeft Member
    142
    24
    Greece
  5. bobodaclown
    bobodaclown Member
    216
    72
    Check out minivci.
  6. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    If you want to replace the brake fluid using the "old fashion way" will not do it.
    It may be capable of removing air in the areas of the wheel cylinders but it will not clean out the old fluid from the rest of the system shown in the diagram below.
    To flush the system effectively the Mini VCI is probably the best "cheapest" solution.
    John (Britprius)
  7. alexeft
    alexeft Member
    142
    24
    Greece
    The old fashion can't be used on the prius anyway. What the guy proposes on the link at my previous post is to actually use the system's pump without using the toyota scantool.
