What are your MPG on commute?
Discussion in 'Gen 3 Prius Main Forum' started by MansTer420, Apr 17, 2013.
  1. MansTer420
    MansTer420 Junior Member
    119
    Prius two
    Avg speed around 65 to 70 on hwy.
    40 to 45 on local
    both mix with EV & ECO mode.
    SAMSUNG-SGH-I317 ? 2
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    My priusIV 52HWY 49 city new tires filled to the top 42lbs. You want great mileage?? fill em up !!
  3. Reedja42
    Reedja42 2012 Prius, Gen III, Barcelona Red, (FRED)
    253
    78
    Mine runs from the mid-50s to over 60 MPG on my work commute; except for winter time, when it runs more like 45 MPG due to the cold and my studded snow tires. It all depends on traffic, temperature, and wind direction. You will discover that when your MPGs are this high, all sorts of things make a difference you can see. You will also discover the how to drive to get the most out of your new ride. Enjoy. :)
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Stop using EV Mode until you know what you are doing.
    My summer commute average (up and down the hill) used to be 57-65mpg depending on how much I hypermile. 100 miles round trip at 60-65mph.
    OceanEyes likes this.
  5. mnsweeps
    mnsweeps Member
    108
    Los Angeles CA
    78 - 82 MPG(downhill) doing to work and around 50 - 60 MPG coming back (uphill). 25.9 miles one way..
  6. MansTer420
    119
    im using EV mode in parking lot and very tiny ally way front of my kid's pre-school to get out.
    on the road, ECO
  7. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    OP, actual mileage may vary from what your display tells you.
    For me, 9 miles fwy to work 60-70 mph. Display reads 52-56 mpg avg.
    9 miles home city streets 35-45 mph stop and go traffic. Display reads anywhere from 54-60 mpg.
    My real world numbers combined, as you can see in my sig, is 51 mpg.
  8. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    From my research, I thought EV is just a gimmick. Even in ECO mode as long as you dont pass the middle bar it will still be in electric only mode. Plus if you run down the battery, the engine is gonna work harder to recharge the battery anyways, which is a big no-no.
    Atleast thats what my research seems to point to.
  9. MansTer420
    119
    in EV mode, even if you pass over the middle bar the car still moves on battery
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Mid 45 range..
    Get a Fuelly account.. great tool to track and share real world MPG's.
  11. HeinzCatSoup
    Southern California
    yeah, but I thought its bad to do that as it runs down your battery, so the engine has to work harder to recharge battery and drive the wheels, wasting even more gas.
  12. MansTer420
    119
    i should have just push myself little bit more and go for PiP.
    PiP can run up to 60mph on battery i heard which is fantastic
  13. Xyrus
    Xyrus New Member
    I have a 2013 Prius 2. I have a 40 mile round trip commute M-W and a 120 mile round-trip commute on Thursdays around the DC beltway (85-95% freeway). Depending on traffic I get anywhere from the low 50's to low 60's MPG (odometer calcs show over 500 miles per tank at fill up). I haven't seen what the cold will do to those numbers yet.
