2013 Prius Persona Modifications?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Toasticuss, Mar 22, 2013.
  1. Toasticuss
    Toasticuss Junior Member
    30
  2. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Fixed the link now. Try again.
    Man, Tapatalk sucks.
  3. Toasticuss
    30
    Thanks for the update, what if your Prius doesn't have original foot well lights?
  4. AZGeek
    627
    144
    63
    Arizona
    Try doing a search for footwell lights. I know others have installed some aftermarket kits on models that don't come with footwell lights from the factory.
    new iPad ?
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I pulled the footlamp out to take a peak at it. This might be helpful to someone who needs to take it apart. See red arrows as those are the tabs that hold it in. Just need to gently spread holder and it's slides out.
    Thank to AZGeek for help.
    Markee likes this.
  6. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    You are aware that if you werent cheap on your 2007 package selection and would have went for a package 5 or 6 than you would have HIDs from the factory right?
    Not being so cheap, my 2008 package 5 had stock HIDs and I have installed them in my 2012. I think I was flashed maybe 3x total for all cars. Either the quoted post is talking about an aiming problem or package-envy but either way it is full of mis-information.
  7. Sfcyclist
    1,621
    375
    SF, CA
    o
    On Gen2's were they projectors? were they just parabolics with autoleveling? I recall older HID lamps being from factory that way.
    Anyone add auto leveler's with HID retro.
    In the midst of the this is, due to the poor retrofit or misadjusted HID, I see more and more drivers with the high beams on intentionally! now that is annoying!
  8. AZGeek
    627
    144
    63
    Arizona
    I never had a problem with the HIDs (factory) on my 2004. Cutoff and adjustment were both fine. Sorry, can't provide any detail on aftermarket auto levelers. My 2012 has the factory auto levelers but I still had to do a manual adjustment after putting on the performance springs.
  9. Sfcyclist
    1,621
    375
    SF, CA
    Which Gen 3 has factory HID's? I thought only Halogens or LEDs but none came with HID.
  10. AZGeek
    627
    144
    63
    Arizona
    My 2004 had factory HID. My 2012 has LED. Sorry for the confusion.
  11. 4everS2K
    4everS2K Junior Member
    Los Angeles
    I installed Kensun HID 4300k about a week ago and since then I've never had any drivers flashing on me. I had once a 2010 Mazdaspeed3 with aftermarket HID (unknown brand, same 4300k) for 2 years and never had anyone flashing on me either. Comparing to my previous Infiniti G37 sedan and current G37 coupe's factory HIDs, these aftermarket HIDs in non-HID housings are pretty good!!!
  12. 4everS2K
    Los Angeles
    I recommend this too.:)
  13. Toasticuss
    30
    Has anyone had any luck replacing their 2011, 2012, or 2013 Prius' light stalk? I am dying to have automatic lights again and see that there is an automatic option in the manual I think for the 5 package. I see that there is also a light sensor on the dash.
    Has anyone put automatic lights in their prius?
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    There is an entire thread about this very same question for the 10-11 gen 3 prius. I'm not 100 % sure but I think the auto lights are only available on the 12-current prius 4 & 5.
    I'll see if i can find the thread.
  15. Toasticuss
    30
    Did you ever find the thread?
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  18. Markee
    Markee Member
    332
    South Florida Broward County
    I'd like to upgrade the floor-well lights on my 2013 level 4 with something a little brighter can someone tell me where I can get the lights at ?
