Is it a bad idea to buy a new 2012?
Discussion in 'Prius v Main Forum' started by FriarNurgle, Apr 18, 2013.
  1. FriarNurgle
    FriarNurgle Member
    138
    53
    After researching it seems that the hv battery could develop issues due to inactivity/non use. Given this information would buying a new 2012 from the dealer be a bad idea even if the price is a little cheaper than a 2013?
  2. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
    Certainly no problem. There is an 8 year hybrid warranty in any case, 2012 or 2013.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    No - you want the price to be much cheaper than a 2013. Somewhere in the 1,000 to $2,000 range.
  4. Lee Bridges
    Lee Bridges Junior Member
    44
    Indialantic, FL
    2013 Prius v wagon
    Check out someplace like KBB.com (Kelly Blue Book) and put in something like 5K miles on a 2012 and the same 5K on a 2013 - I would say that if the cost spread being offered by the dealer wasn't equal or greater, then pass on the deal.
  5. mikefocke
    3,992
    1,801
    Sanford, NC
    Nothing wrong or significantly different between the '12 and the '13. Use the perceived age of the car and its worth in the used car market to negotiate the price down, then keep the car for 10 years until the value depends on condition and not so much on age.
  6. ETC(SS)
    7,139
    How old is the '12?
    If it was manufactured late in the year, it might not be as old as you think it is.
    Also...as noted above the hybrid components are covered by a longer warranty - especially if you live in a CARB state.
    No worries.
