Has anyone used these window visors?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by burstaneurysm, Apr 10, 2013.
  1. peterjmc
    917
    188
    Clarksburg, MD
    James4455 likes this.
  2. Mark C.
    Mark C. New Member
    Arab, AL
    Has anyone noticed a difference in fuel economy after installing the window visors? It looks like it would create a small amount of aero drag, but is it noticeable on your mpg?
  3. wotcher
    wotcher Member
    403
    97
    LA
    I see a "significant" difference in yours and the oem jdms. your second and third pictures illustrate this point. The jdm ones are very flush and don't stick out as much. At the socal prius meet, I was able to inspect multiple window visors. And the true jdm ones were the nicest. Of course, I'm also tempted by price. so do you have a link for your jdm replicas. Or are you using the hics?
  4. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Yr right the Toyota Japan ones sit slightly more flush but the design is very similar, but price difference is huge.
    Was wondering dont the Toyota dealers sell these? Here in UK they do but they are clear and not tinted.
    These are the ones I bought, eBay item number 350559586454.
  5. aportades
    aportades Team Thrust Racing
    76
    177
    San Diego, Ca.
    Thanks for the compliment!!
  6. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Well, the visors I ordered came in. Unfortunately, they were not the ones in the photo... they were the style that aportades has, which were my second choice anyway.
    I contacted the seller who apologized for the misrepresentation and refunded me 20%. I'll take it.
    Too cold to put em on today, hopefully, it warms up a bit tomorrow.
  7. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Any photos?
  8. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    Tampa, FL
    got them in not the best quality but for the price im satisfied. It seems like the do a poor job cutting out the visors as my rear visors are wider then the fronts, but the overall design is still fine. I can complain for $40.
  9. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    That seems pretty bad quality.
    Never seen that style before until recently and not really that keen on it, why does it go inward on both the front and back visors?
  10. burstaneurysm
    469
    144
    Chicago, IL
    Here are the visors installed. Not bad.
    iPhone ?
  11. artnsx
    artnsx Junior Member
    i think they look fine, do you see any point to having those indentations towards the rear of the front one and the front of the rear ones other than visual appearance? i might just go with the stock looking ones to avoid adding more lines to the side of the car since that 3rd option is eliminated for now.
  12. burstaneurysm
    469
    144
    Chicago, IL
  13. burstaneurysm
    469
    144
    Chicago, IL
    It's also worth noting that the image in the ebay auction is a Civic with Mugen visors.
  14. BreitrthnU
    255
    Tampa, FL
    they make that style for the prius too, but those i think are ugly.
  15. zeoth
    zeoth Junior Member
    43
    OEM ones are held on by 3M tape anyways. The only difference is a small clip that will probably break if you fart on it.
  16. burstaneurysm
    469
    144
    Chicago, IL
    The biggest difference between OEM and the ebay ones is the clarity of the plastic.
    OEM plastic is almost transparent, but the ebay ones aren't as clear. Again, considering the cost difference between the two, I can't justify the legit ones.
  17. wotcher
    wotcher Member
    403
    97
    LA
    I think the biggest difference is not the clarity but the thickness of the visors. Look at BigPete's #2 and #3 pictures. they stick out a lot. The jdm ones are very flush and don't stick out as much. At the socal prius meet, I was able to inspect multiple window visors. And the true jdm ones were the nicest. Of course, they cost an arm and a leg. :(
  18. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    it's too hard to dry the back, and clean the window under the one that don't stick out very far. I've have the HIC ones for nearly 43 years now, and haven't had an issue with them.
    Tracksyde likes this.
  19. priusoup
    priusoup Junior Member
    25
    2012 Aqua
    A couple of things have been said but I like the visors because 1. I can park my car and crack the windows open and feel more secure about not having someone coming by and possibly breaking in/tossing something inside my car, 2. If there's rain I can crack my windows open without risking water flying into my face, 3. It just looks better. Hah.
    mgb4tim likes this.
  20. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    They do not make this style for the Prius.. Not that I know of.. If u see this pic being used for the Prius u will get the ones that have the indents in the center where the two visors meet..
