There's a Blizzard in Socal!
Discussion in 'Gen 3 Prius Main Forum' started by blizzardprius714, Apr 23, 2013.
  1. blizzardprius714
    blizzardprius714 Junior Member
    25
    Just picked her up late yesterday, 2010 PIII, 25K-miles.
    I was never big on hatchbacks but the 3rd generation Prius is such a nicely designed vehicle. Just wanted to share this first photo:
  2. Fong
    Fong Member
    85
    32
    Arizona
    Congrats!
  3. Tideland Prius
    16,621
    Congrats and welcome to PriusChat!
  4. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    The Prius 3 certainly is definitely the best looking Prius of them all. Actually the best looking hybrid among all hybrids.
  5. blizzardprius714
    25
    Thanks! Now I just have to figure out how to play Pandora/audio thru the bluetooth with my Samsung s2.
  6. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Congrats. The pandora should play automatically if you have your phone hooked up via BT, and you select BT as the audio mode. BTW, which app did you use to get that soft effect in your pic?
  7. blizzardprius714
    25
    okay, I'll set BT as audio. Does this override BT phone or can they coexist with phone being priority?
    Used Photoshop, but there may be online services that make it easier and quicker.
    p00kienrayray likes this.
  8. p00kienrayray
    720
    135
    Long Beach, CA
    Phone is automatically priority whether BT audio mode is selected or not.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Thought you had an actual blizzard for a moment. We got 3 inches of snow last night and it is still below freezing and snowing now. :)
  10. p00kienrayray
    720
    135
    Long Beach, CA
    Yikes!
  11. blizzardprius714
    25
    Lol no real blizzards here just clear skies and warm weather (you probably didn't want to hear that)
  12. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Mine's doesn't neither and I believe it works only if your iPhone is setup as hotspot/tethered?
  13. p00kienrayray
    720
    135
    Long Beach, CA
    If you're using entune then yes ur iPhone has to be tethered. OP has a 2010 without entune, so Pandora has to be streamed via BT, though it may be streamed via USB as well, not sure.
    Speaking of entune, I find it easier to just use BT pandora instead of tethering it. The track info and album cover art still shows up.
  14. Sfcyclist
    1,621
    376
    SF, CA
    hmm.. with have to try that.
  15. blizzardprius714
    25
    Just got her tinted, 35% all around. Just in time for Vegas trip tomorrow.
  16. Sfcyclist
    1,621
    376
    SF, CA
    tried it and works sporadically. most consistent method for Pandora for me is tethered.
  17. p00kienrayray
    720
    135
    Long Beach, CA
    Really, it's worked 100% for me so far, but then again I don't really use pandora much.
  18. Sfcyclist
    1,621
    376
    SF, CA
    I used it regularly as my kid loves it.
    Mines get confused and sometimes streams ipod instead of pandora. ugh.. even when I see it pandora playing on the phone, the music from ipod is playing through the speakers..
  19. p00kienrayray
    720
    135
    Long Beach, CA
    Ya know, I've been experiencing weird things with the stereo too. For instance, sometimes the ipod would stream thru the stereo, and sometimes it would just play through the phone (BT or tethered) even though the info is loaded on the stereo screen. Sometimes when I power off the audio on the stereo, the ipod (when tethered) would just turn itself back on. Very glitchy system. Never experienced anything like this on the non-Entune system.
  20. Sfcyclist
    1,621
    376
    SF, CA
    This must be software issue and system performs different actions or scans based on what's detected... I'm just glad I was able to stream Pandora with tether method consistently. Even with hardwired method, it's not consistent BUT I do know methods to solve it consistently.
    Via BT, I have not found a way to effciently solve the problem.. I've even had to reset my phone because Pandora crashed my iPhone!
