Help 2001 prius stalls when I put it in gear
Discussion in 'Generation 1 Prius Discussion' started by Tdorr, Apr 24, 2013.
  1. Tdorr
    Tdorr New Member
    2001 Prius
    I have a Prius 1st gen and I just started having this problem yesterday. I started the car and the warning lights came on but the engine started. Then I put it into gear and the car stalled, engine shut down completely. Then I put it back into park and the engine started up again. So I put it into drive again and the engine shut down again, put it back into park and the engine started up. So I turned off the car and waited several minutes, started the car and put it into drive gear and was able to drive it to a mechanic. He said they couldn't get a code reading on it. Has anybody else had this problem and do you know what could be causing this intermittent problem?
  2. bwilson4web
    16,217
    Were there still warning lights?
    Do you have warning lights now?
    From what you have described, the ambiguity group, the list of things that could have failed, is too large to tell. If it is intermittent, it will be difficult to diagnose without a prius-aware scanner.
  3. Tdorr
    Tdorr New Member
    2001 Prius
  4. Tdorr
    Tdorr New Member
    2001 Prius
    Yes, there were warning lights and there are still warning lights ( PS and triangle with exclamation point). The auto mechanic shop is not a dealer but does deal with other Prius cars and says he has a prius-aware scanner.??
  5. bwilson4web
    16,217
    Where are you located? The reason I ask is we may know of someone to get a second opinion.
  6. Tdorr
    Tdorr New Member
    2001 Prius
    I live in a small town in Southeast Iowa, Fairfield
  7. bwilson4web
    16,217
