300+ HP Prius Liftback! - This is what we want.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by jameskatt, Apr 27, 2013.
  1. jameskatt
    jameskatt Member
    148
    Monterey, CA
    Imagine a 300+ Horsepower Prius Liftback that will smoke many cars on the road in acceleration and get BETTER gas mileage than the regular Prius.
    It is possible today.
    It is what Toyota should add to the next Prius.
    Check out Fox Marketing's customized and supercharged Lexus CT 200h Hybrid. It has the same engine as the Prius Liftback but customized to get over 300+ HP and better fuel economy!
    Supercharged Lexus CT 200h hybrid will tear your arms off with 300 HP
    Fox Marketing Lexus CT200h
    The customizations are as follows:
    ENGINE
    Eaton Supercharger System (300 hp est.)
    Climax Racing intake manifold
    Yonaka air to water intercooler (22x9x3), 2.5 inch stainless intercooler piping, couplers and silicone hoses
    Boosted factory battery power
    WHEELS/TIRES
    iForged Concove Insite wheels
    o 20x9.5, front
    o 20x10.5, rear
    Toyo T1R tires
    o 225/30/20 front
    o 255/30/20 rear
    BRAKES
    BAER front brake upgrade
    o 13-inch rotor
    o Four-piston opposed caliper
    SUSPENSION AND CHASSIS
    Road Magnet two-inch springs
    EXTERIOR
    Lightwurkz Custom BASF R-M Carizzma Flat Black headlight casings
    Custom lip molded front spoiler, side skirt, three-inch fender flares, rear bumper flare
    Custom BASF R-M Black grille inserts and Lexus rear logos
    Impressive Signs custom CT badging
    BASF R-M waterborne Carizzma Cinnamon Quarts Pearl and Black paint
    INTERIOR
    Custom LED Lexus logos in door panels
    Yonaka Ronin racing seats with black leather, red stitching and brushed aluminum trim
    51,883
    i can't believe i had to watch a herb chambers ad to see the video.:rolleyes:
  3. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    I got a Chevy Cruise Eco ad. Don't think the very vague MPG claim will hold up. What was the battery KW contribution? Boosted battery? Wider SoC range for shorter life? Emissions? Still it was nice looking.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    You won't get better fuel economy. It just never pans out despite claims from supercharger/turbocharger companies. I highly doubt the drivetrain could handle an extra 166hp on a regular basis. I have been through more than enough supercharger and turbocharger systems to know what I'm talking about. Or you can ask Ford..... Hahaha
    It's a pipe dream and a lot of us don't want any part of it.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Why do I want 300+ HP? I am not stupid enough to be fooled into thinking I need that much power. The Prius with its meager HP can accelerate onto the highway and keep up with traffic. 300HP is completely wasted in any commute. If you believe you need that much HP to be happy, you are just stupid.
    dogfriend and minkus like this.
  6. bwilson4web
    16,201
    Lately I've been monitoring ICE rpm with our NHW11 when starting from stop lights with multiple lanes of traffic, mostly two sometimes three. What I've found is a modest 2,400 rpm puts me right in the middle of the pack and this is not a whole lot of power . . . and very efficient.
    Yes, sometimes I'll punch it if three lanes turn into two and I don't want to have to merge into dense traffic. But I've never felt any problem passing on two-lane roads by doing it right:
    • time acceleration behind the leading vehicle so on-coming traffic passes first
    • pull into passing lane and continue acceleration until just passing the vehicle
    • pull back into the lane and back-off power to resume cruise speed at the posted limit
    The only reason for passing is the lead vehicle is significantly under the posted speed limit. It happens, often with 'handicap' license, trailer, or elderly driver.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are times I drive like an idiot and keep up with "the pack" at triple digit speeds and the Prius does fine. 300HP is useless.
    markabele likes this.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    Worse yet, when you try to use all the extra proposed power, your fuel economy tanks. That is why the EcoBoost, and other small engine turbo ideas, simply do not produce big FE numbers. Anytime you stomp the go pedal your fuel mapping goes from fuel efficient mode to fuel dump mode.
    chughes123 and Sergiospl like this.
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Yep, $60,000 is about right. 2 extra mpg on a 5-mile loop for a total of 44mpg? Sure!
    Engines with forced induction have more power for a smaller displacement, but are not known for fuel efficiency.
  10. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    sorry guys, fox marketing cars are... marketing... one off cars not really tested at all.
    so forget about those claims and enjoy them for what they are... one-off concepts.
    F8L likes this.
  11. david_cary
    david_cary Junior Member
    47
    17
    CRs driving style punishes fuel dump modes rather significantly. They nearly floor it quite a bit and so their numbers always punish a turbo. Doesn't make them right. Haven't you seen their Prius mileage - so hard to get that kind of mileage in the city on a Prius.
    So yes - CRs numbers are good for comparing how cars behave when you "drive it like you stole it". Their highway numbers are better though.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  13. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    So complicated. Put an electric drivetrain in there and enjoy the effortless power and smooth driving experience (and double the fuel efficiency):)
  14. walter Lee
    1,126
    376
    Maryland
    The Prius' Atkinson cycle ICE has this long power lag/delay. Would increasing the HP Atkinson cycle engine make it all that much faster? I would think a wider and stronger electric motor performance would be more helpful in speeding up the Prius but would not this require a more powerful HV battery (or Ultracapacitor add-ons) with higher peak current performance?
    Toyota is looking at adding hybrid tech to its sports car the Scion FR-S. For right now I think the Honda CR-Z is the only hybrid sports car out... but they are still rarity in my area.
  15. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I would believe the HP & MPG increase only if they added an Aquatune Water Injection system :rolleyes:...
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ouch, I just noticed the 20" wheels. That alone will kill mpg. lol
  17. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Yes, but the 9.5" 10.5" width coupled with the high performance tires should also give a net gain in MPG...
    I can't believe you are questioning this rocket scientist. His 5 mile loop should give you total proof that he's legit. Of course if he puts another 200 miles on it, that should unequivocally prove his claim.
    F8L likes this.
  18. windstrings
    6,280
    378
    Central Texas
    I've wondered if it's the wheel size or the gearing of he synergistic system that has been designed for 15" wheels?
    Looking at extremes.... What if the wheels were 3 inch wheels, that would be totally crappy gas mileage with "lots" of torque below 10 mph.
    Or let's be a little more reasonable... What about 10 inch wheels?
    It can't be wheel weight?
    I can throw another 2 adults in the back and not notice a mpg difference?
    Alan.. Sent with Tapatalk 2
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Tire diameter generally stays the same when you upsize so it's not gearing. It's a combination of extra weight (larger tires are A LOT heavier) and tire design. 18"+ tires are not LRR. Even 17" tires are not very efficient yet.
  20. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    Oh boy, I'm sure that's going to be reliable...
    kgall likes this.
