Question about difference in energy star A/S tires
Discussion in 'Gen 2 Prius Main Forum' started by roflwaffle, Apr 28, 2013.
  1. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I noticed there are a couple versions of the energy saver a/s tires. One is heavier and has a higher speed rating/load capacity. Does anyone know if there's anything different about the Crr of these two tires, or is one just a smaller/lighter version?
    P185/65R15
    86T SL
    LRR: Green X 480 A B 1168 lbs. 44 psi 9.5/32" 17 lbs. 5-6.5" 5.5" 7.4" NA 24.5" 851 CA
    185/65R15
    88H SL
    LRR: Green X 480 A B 1235 lbs. 44 psi 9.5/32" 18 lbs. 5-6.5" 5.5" 7.4" 6.2" 24.4" 851 CA
  2. Mendel Leisk
    41,310
    Are you talking about Michelin Energy Saver A/S tire?
  3. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Yes. I'm just mixing the kuhmo/michelin lrr names.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yes, just a difference in load rating (construction). You want the T rated tire for best FE. If you drive aggressively and or drive on very rough roads or gravel I would go with the H rated tire because it should be a little more robust.
    roflwaffle likes this.
