Turning off the reverse beep on a 2012 Prius v
Discussion in 'Prius v Accessories and Modifications' started by edgrzy, Oct 10, 2012.
  1. joerockt
    joerockt Junior Member
    97
    27
    This is the only method that works. You can't use the procedure that worked on the Gen II.
  2. D_J
    D_J New Member
    Thanks for the follow up.
  3. PixelRogue
    317
    57
    US
    Have access to multiple Macs, iPhones and iPads. Not a single android device or PC. Anyone with options on how to modify the car setting using Mac? (success using the emulator idea above?)
    - turn off reverse beep.
    - open all doors via proximity (always wanting to open back door first to toss in bags etc)
    - turn off GPS motion lock. (or set to allow passengers to operate ... sensing weight on seat?)
    - any way of remote opening hatch? convert panic button to remote open hatch?
    - any way to auto-turn on day-time running lights?
    (never understood why my 1999 Camry had a sensor for auto adjusting day-time running lights/dash etc, and my 2010 Prius V doesn't)
    UPDATE:
    There is Engine Link for the iOS which is supposed to work w/the Soliport ELM 327. (not yet verified)
  4. PixelRogue
    317
    57
    US
  5. mike Hilton
    mike Hilton New Member
    Dunfermline, Fife
    I've had the reverse warning changed to a single beep but can this be turned off completely?. Since fitting aftermarket reverse sensors I've now got two beeps when selecting reverse. It's a bit annoying and would be better with just one. I'm not sure if my reversing sensors initial beep can be silenced.
  6. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Mike, a single beep and continuous beeps are the only choices in software.
  7. mike Hilton
    Dunfermline, Fife
    Thanks mate. I'll have to live with the double beep.
  8. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    Thank you also, mandasol, from me. I ordered my OBDII scanner over the weekend and it arrived Monday - pretty quick service. I made my way through your instructions and voila! no more reverse beep. That was pretty slick.
    Regards,
    Allen
  9. PixelRogue
    317
    57
    US
    No success yet through the iPhone or Mac. Part arrived, but nothing picking up the bluetooth signal.
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I just had mine changed today at the dealer - free!
  11. abistro
    abistro Junior Member
    22
    Virginia
    Excellent instructions. Worked perfectly, single reverse beep and turn off seatbelt notification. Thanks!
  12. srfndoc
    srfndoc Junior Member
    SoCal
    2013 Prius v wagon
    Thanks to Mandasol for the tip on the cheap OBDII scanner on Amazon and the great instructions
    for disabling the annoying reverse beep. Other than the reverse and seatbelt beeps is there anything else people
    disable on a regular basis?
  13. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    I turned off the headlight delay, but you can do that without OBDII
  14. RamAirDave
    RamAirDave Junior Member
    28
    Yukon, Oklahoma
    I tried this today but only got 12 pids to show up what did I do wrong?
  15. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    You have a gen 2 Prius, not a Prius v. So you want a similar thread in the Gen 2 forum.
  16. RamAirDave
    28
    Yukon, Oklahoma
    Excellent. Thanks, I thought this one was for gen 3
  17. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Do you not have a 2008 Prius? That is Gen 2.
  18. RamAirDave
    28
    Yukon, Oklahoma
    I need to update my profile. We picked up a black cherry pearl persona yesterday. 2013
  19. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Ah, then I am giving you bad advice. The dealer can set that, and I would have made it a condition of sale if it was me.
  20. RamAirDave
    28
    Yukon, Oklahoma
    I just thought it could be done with the torque app. Is that not possible?
