Tire change recommendation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joeuser, Apr 30, 2013.
  1. joeuser
    joeuser Prius Junkie
    78
    NYC
    I'm at about 45K miles on my Gen-II 2009 Prius III.
    Was advised to change my tires when I last took the car for some service. I haven't been very diligent about having them rotated every 15k miles. I'm going to be with my next set.
    My car info on the dash shows about 50.8 mpg as of today. I live in NYC and this winter has brought that number down from about 52 ish to 50.8 and it is now finally back on the rise. I didn't like the road noise when the road was made of anything other asphalt, normal tar-based roads were not so noisy in the inside.
    I've got the OE Goodyear Integrity's on and I run them at 40/38 psi (front/back).
    I started looking at replacement tires at tirerack.com and am simply lost.
    I read about a few Yokohamas.
    Namely the Yokohama dB Super E-Spec and the Yokohama AVID Touring-S.
    The last time i really thought about tires was when I bought the car and thought I would replace the tires with something like the Nokia i3's but they are just not easy to buy here (or can I buy them in NYC?).
    My criteria is to keep getting the same great mileage and maybe have better handling/less road noise while driving. I also plan to stick to the same measurements P185/65R15.
    Please keep in mind that the winters are snowy however I never had any trouble with the Goodyear Integritys so far whenever I was on the road.
    Any other tire recommendations/suggestions are welcome.
    I would love to be able to get some Nokians on this car.
    Thanks.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    In snowy regions I recommend the Ecopia EP422 but if you didn't have trouble with the Integrity (horrible in wet weather) then you could get away with the Energy Saver A/S. unfortunately, tires with much better handling will bring down fuel economy. With higher air pressure, the Energy Saver A/S handles fine and is the most efficient tire in NA.
  3. joeuser
    78
    NYC
    Looked into the Bridgestone Ecopia EP422 after your recommendation. Seems like the ideal candidate.
    One final question: How good is Costco Tire service for the Prius in terms of installing/alignment? or should I have them installed elsewhere?
    Thanks.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    My experience with Costco is that they don't do alignments.
    Merkey likes this.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Costco is great except they don't do alignments. :(
    They also take the $70 rebate off your final bill instead of charging you full price then making you apply for the rebate.
    Merkey likes this.
  6. joeuser
    78
    NYC
    Exactly my thought. I even told them I want to keep the rear tires because they still have considerable tread left. Could probly sell them off locally.
    Also i'm guessing they will inflate the tires to the recommended spec of 35/33.
    Costco uses nitrogen. And I'd like to be able to use my 12V tire inflator (compressed air) to inflate upto 40/38 like I currently have it. Will this cause any problems mixing nitrogen and my good ol' air compressor?
    Thanks.
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    This subject has been brought several times in various places. The answer is yes, you can mix compressed air and nitrogen. However, when you do that you are diluting the nitrogen therefore eliminating the purpose of the nitrogen in the first place.
    Take a look at the following link for more information.
    Can You Mix Air And Nitrogen In Tires? | Nitronomics
    Ron
    F8L likes this.
  8. joeuser
    78
    NYC
    Thanks for the input everyone. I had the OE tires changed yesterday with the Bridgestone Ecopia EP422 P185/65R15 at Costco.
    Good deal. Free rotations every 7500 miles (can't go wrong with that), full tire warranty, etc.
    I haven't felt the big difference yet but I do feel that there is less noise now that there was with the Integritys.
    They managed to inflate them to 40/38 PSI as I wanted (with nitrogen).
    I'll see how the fuel economy pans out over the lifespan.
  9. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    If your rear tires a good yet, why not just get two new for the front? :) H
  10. softrider316
    softrider316 Junior Member
    Montclair, NJ
    While getting a set of Michelin Defender XTs installed at Costco, I was surprised to see a recommendation by Goodyear on the counter. They were recommending that if one is only installing a pair of new tires (not a complete set), that the newer tires should always go on the rear, regardless if the car was front or rear wheel drive. At first I was a little confused as my previous impression was that the front wheels do all the steering and are also responsible for the majority on one's braking ability. So I did a little research and found a nice explanation at TireRack regarding this recommendation in their Tire Tech Information/General Tire Information section under an article titled: Where to Install a New Pair of Tires. Unfortunately haven't posted enough articles to allow me to provide a link, but here are a few excerpts:
    New tires on the rear axle help the driver more easily maintain control on wet roads since deeper treaded tires are better at resisting hydroplaning.
    If the front tires have significantly less tread depth than the rear tires, the front tires will begin to hydroplane and lose traction on wet roads before the rear tires. While this will cause the vehicle to understeer (the vehicle wants to continue driving straight ahead), understeer is relatively easy to control because releasing the gas pedal will slow the vehicle and help the driver maintain control.
    However, if the front tires have significantly more tread depth than the rear tires, the rear tires will begin to hydroplane and lose traction on wet roads before the fronts. This will cause the vehicle to oversteer (the vehicle will want to spin). Oversteer is far more difficult to control and in addition to the initial distress felt when the rear of the car starts sliding, quickly releasing the gas pedal in an attempt to slow down may actually make it more difficult for the driver to regain control, possibly causing a complete spinout.
    So while one should ideally get a full set of new tires, if you can only afford a pair or if you feel that there is enough tread left on a pair (common when one doesn't rotate the tires too often), the older pair should be mounted on the front and the newer pair on the rear. But bear in mind if you only install a new pair of tires, you will never been able to rotate your tires but will be stuck with a mismatched set and the requirement of having to replace one pair at a time as the older pair wears out.
    HaroldW likes this.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    No worries. We've battled this out in numerous threads on PC. New tires (or ones with the most tread) always ton on the rear. Period! ;)
  12. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    There is a difficulty with the above, I agree splitting hairs. If you put a full set of tyres on a front wheel drive car in theory you can never rotate them. The fronts will always ware faster and have less tread than the rears. Rotating them will break the rule of always having the best tyres on the rear. This may only be 1/32 in 5,000 miles but it still breaks the rule.
    John (Britprius)
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye, we are splitting hairs. Maybe the rule should state a minimum difference in tread depth or we could go further and discuss weather conditions. In most of California we receive no precipitation from June through October so it may be safe to perform a rotation that puts the less treaded tires on the rear during this time to promote even wear. That being said, the spirit of the idea is that if you have two sets of tires with greatly differing tread depths then the ones with the most tread go in the rear and yes you will lose the ability to rotate them unless weather conditions dictate otherwise. :)
  14. Britprius
    5,194
    1,921
    I agree my comments were meant to be more thought provoking than saying it should not be done.
    When I first started driving I had access to a bus driver training scid pan with chief instructor "brother in law" on which I spent many hours. Even drove London type double decker buses on there, "do not believe you have double deckers in the US".
    This taught me a lot about skid control, the hardest thing to learn was not to brake during a skid. Went on to rally and race the original Mini's and these were set up for a loose rear end "oversteer" partly because the brakes were so poor the best way to slow the car down was to slide it sideways. Best tyres were always on the front. How times change.
    John (Britprius)
    F8L likes this.
  15. HaroldW
    716
    95
    I still prefer the better tread up front, especially during the winter. FWD. Mind you I drive at the lower side of the speed limit! Actually much slower :). So really not much to worry about. H​
  16. Mendel Leisk
    41,258
    The front tires will wear faster. Put the new tires on the back and they'll never catch up to the front for wear.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    The rear tires will catch up to the front..... During severe oversteer due to hydroplaning. :p
  18. HaroldW
    716
    95
    Your bang on with that comment F8L:( . H
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    As an exercise in reductio ad absurdum, one should never rotate the tires on a FWD drive car because the front's wear faster, so each time you rotate the tires the best tires end up on the front.
