2006 Reverse Beep Killer
Discussion in 'Gen 2 Prius Main Forum' started by Flujo, Feb 2, 2006.
  1. Flujo
    Flujo New Member
    LA
    I recently sent the reverse and seat belt beep killer instructions to a buddy with a 2006 Prius and he swears that it does not work. Anyone know if there has been a change to the 2006?
  2. northvan
    northvan New Member
    British Columbia, Canada
    I have a 2006, and had no problem killing the reverse beep using John1701a's instuctions
  3. Flujo
    Flujo New Member
    LA
    Thanks. I think the problem is with the nut behind the wheel.
  4. Flujo
    Flujo New Member
    LA
    I do not have John1701a's instructions...can you send them to me or point me in the right direction?
  5. kdmorse
    kdmorse Member
    205
    Germantown, MD
    To disable reverse beep (step by step) - works on my '06.
    1. Turn the car on
    2. Use the ODO button to cycle to ODO ( not trip A or B )
    3. Turn off the car
    4. Foot on brake, Power the car into Ready, keep foot on break
    5. Within 6 seconds, press and hold ODO for at least 10 seconds, keep it pressed
    6. With ODO still pressed, Shift into Reverse with the gearshift
    7. Once in Reverse, press the Park button
    8. Release the ODO button
    9. ODO should read b-on (Beep - On). Press the ODO button to switch it to b-off (Beep - Off)
    10. Turn off the car
    Rumor has it the operation will fail if there is anything in the passenger seat weighty enough to trigger the passenger detection.
    -Ken
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    so it DOES work. good to know. useful for in the shop. thanks guys :D
  7. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    Note that those instructions are old. We discovered a unique circumstance that took awhile to figure how to overcome. But we did. We also disspelled that weight in the passenger seat belief.
    Check out page 4 of the USER-GUIDE for details and photos.
  8. Begreen
    Begreen Member
    670
    Western WA state
    Has anyone wired/configured the system so that it would beep a rear-external beeper? This would seem to me to be much more valuable and safe (for pedestrians) and I would still probably hear it.
  9. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    I let someone who is 6 foot 7 inches tall try out my 2006 a few days ago. His knees were about a half inch from the gear shifter. Now, just think what might happen if he hit that gear shift without knowing. You guessed it......it would go into reverse. Without those beeps he would not have had any feedback of the change. If he was at a stop sign when that happened my guess is he might accelerate right back into the car behind you.
    Moral of the story.......keep them nutty beeps.
  10. Kathleen2
    Kathleen2 New Member
    77
    I did it and it was simple and easy. Took me 20minutes because I'm old and slow. Cost less than $10.00. It can be heard inside and outside.
    Go to Main Forum "Has Any one deactiveded the beeping" post #18 by Dodiva.
    The instructions and pictures couldn't have been better.
    Kathleen
  11. Begreen
    Begreen Member
    670
    Western WA state
    Thanks Kathleen. I came to the same conclusion for installation, but didn't have the Radio Shack part number. That helps. I am also looking at the Wolo unit for exterior mounting.
    http://www.wolo-mfg.com/back-up.htm
    PS: for other searching here - the poster's name is Godiva. on this thread:
    http://priuschat.com/index.php?showtopic=15219&hl=beeping
