Gas Mileage No Better than Civic HyBrid?
Discussion in 'Gen 3 Prius Fuel Economy' started by oldgoat99, May 5, 2013.
  1. oldgoat99
    oldgoat99 New Member
    Spring, TX
    First... I'm sorry for the long post but thought I'd try to answer at least some of the questions that may come up.
    I have two friends that are Prius owners (one has a gen II and one has a Gen III). My brother also owns a Gen III. In all cases they are claiming 47-53+ MPG as an average. My brother told me his worst tank measured 46 MPG on a trip through Texas when he was driving on a highway where the speed limit was 85. His best tank measured 60 MPG on a round trip excursion on the Pacific Coast Highway. He lives in northern Arizona and the weather there is cold during the winter months with snow happening a number of times during the cold season. In all cases they are measuring the actual MPG and not using the MPG indicated by the onboard computer which reads higher by 2-4 MPG,
    again, in all cases.
    This isn't my first hybrid. I bought a Honda Civic Hybrid at the end of 2005. I had it for two years. Gas mileage was consistantly 40-41 MPG The last 4-5 months I had it, it started having major mechanical issues. I took it in to the dealer 6-8 times and had many heated discussions with them. They were never able to fix it and I ended up trading it for a Nissan.
    Ok, fast forward to 2013... I decided to try the Hybrid route again. last month I purchased a 2013 Pruis (Gen III). I'm on my 5th tank of gas and I'm pretty disappointed in the MPG. The first 4 tanks I got less than 41 MPG. As I said this isn't my first hybrid but just in case anything has changed I've viewed a number of videos on "getting the best mileage and *think* I'm doing the right things.
    The tire pressure is 40 PSI all around and the oil is at the full mark on the dip stick. I live in Houston so the weather has been in the mid 70s to mid 80s except for a couple days when it dropped to the
    low 40s over night. I do use the "B" mode on the shifter when I see trafic slowing and go back to "D" for normal driving and I also try to space out my breaking so I get maximum power regeneration during stops. I do all my driving in ECO mode (the green ECO mode indicator on the display is on).
    I've had the car a month. I've taken two short trips, one from Spring, TX to Dallas and back and one from Spring to Austin and back. The rest of the miles were in town driving, all relatively flat areas.
    When I drive the car I've found out a few things that may or may not have anything to do with why my gas mileage seems to be low (at least to me).
    Here are my observations
    1. When I start out in the morning the battery indicator on the dash is always at half or one or two ticks above half.
    2. It's impossible to stay in electric mode until I've driven 6-10 miles. I can then use electric only but even then it's touchy at best.
    3. The battery indicator quite often goes one to two ticks below half. I guess I'd expect that but it does seem to
    4. spend a lot of time there. Once the ICE kicks in it will eventually go to 2 tick above half but doesn't seem to stay there long.
    5. The instantaneous MPG indicator is acting like I would expect it to act considering the gas mileage I'm getting. When I'm accelerating it goes to about 10 MPG and when I'm cruising along in electric mode it's at 100 MPG. If I'm cruising at 50-65 miles per hour the MPG indicator is always reading below the 50 MPG mark by a couple ticks. When cruising at other speeds the MPG indicator varies but is almost always below 50 MPG.
    6. Now there have been a few and by a few I mean 3 or 4 occasions where I've been cruising along at about 45 -50 miles per hour where the battery indicator went to 3 ticks above half and when this happened the instantaneous MPG was indicating about 60-70 MPG for a mile or two but as soon as I had to slow down or stop at a light it would go into it's old mode. The battery indicator drops to 2 ticks above half and the instantaneous MPG goes to crap again. Like I said I've only experienced this on a 3 to 4 occasions.
    7. Another thing I've noticed is that when I accelerate from a stop, even very slowly, the indicator that indicates "PWR" mode (the last inch of the indicator bar that turns red) goes into the red area. It's like the battery assist...ISN'T. Yes, the MPG jumps to 100 MPG for a split second when accelerating from a stop but then drops to 10 MPG and the bar goes into the red PWR section.
    I'm not saying anything above is a problem with the cars operation. The points are just my observations. But, why is my gas mileage so much worse than what most everyone else seems to be getting?
    Am I expecting too much to ask for better MPG from my Prius that from my Honda Hybrid?
    I haven't taken it back to the dealer yet. What do you guys think. Do I have a problem or is less than 41 MPG acceptable?
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Probably the most counter-intuitive aspect of these cars is that you want to use the battery as little as possible.
    The two things that you mention that I'd get away from are 1) using the "B" selection on the shifter and 2) working hard to stay in EV mode.
    Number 1 is because while there is some battery regen while you do this, you can recover much more of your kinetic energy by simple braking. If traffic permits, try to brake early enough to keep the regen area of the HSI a little less than full.
    The car has its own strategy regarding the state of charge for the traction battery. There's no sense trying to manipulate it.
    EV mode is efficient in stop and go traffic and other slow (say, 30 mph or less) mostly because using the engine isn't so efficient in those speed ranges. At any other time try to push into the upper half of the ECO range so that the engine is doing the bulk of the work. Whatever you pull from the battery for EV use was put in by the engine (with some lost) and more is lost in driving the motor with it. The 100 mpg you're seeing as you first start off is because the engine hasn't started yet. As seductive as the "100 mpg" indication is, there's no free lunch. Your engine already did the work to put that energy into the battery and you're only getting part of it back.
    You no. 7 observation is perfectly normal. It feels like you're getting no electric boost mainly because you're using ECO mode. I go through phases in which I can't stand ECO mode. You might do better to turn that off to see if it helps.
    Sorry about all the words. Let me summarize:
    - Don't worry over the rate you accelerate at. You might as well keep up with traffic while you're accelerating.
    - Coast when you can. If you don't need to slow down, put a little pressure on the gas to get out of the regen zone.
    - Brake early so you can brake gently.
    - Unless you need to accelerate gently, push enough to get the engine involved in any accelerating you do.
    - Chris
    P.S. - Welcome to PriusChat!
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Chris is correct.
    Stop trying to maximize regen during braking. Instead, coast/glide for as long as possible. You should only touch the brake just before you stop. In theory anyway.
    Do not try to keep the car in EV. You want to use as little energy as possible and this includes EV power.
    If you wanted max efficiency you should have skipped the Persona model and the mpg sucking 17" wheels. Do you know which tires you have? I pray that you don't have the Primacy MXM4 upgrade.
    I would also make not of how quickly the engine shuts down at a stop light with the A/C and heater off. If it takes a long time for it to shut off despite the engine being warmed up then you could have a bad 12v battery. Sometimes the dealer showcases the car and wears out the tiny 12v battery prematurely. This can have a negative affect on fuel economy. If you or the dealer ever had to jump the car I would be very suspect about the battery condition. This happened to my Plug In so I made them exchange the battery as a condition of the sale.
  4. oldgoat99
    Spring, TX
    Ok, I'm going to drive it like normal, quit worrying about what the indicators are telling me and coast as much as possible. I'm not one to have to be the first one get to or leave a stop but I try not to hold up traffic either. I'm running in ECO mode now and will see how the mileage is at the end of this tank of gas. I'll switch out od ECO mode for the next tank and see how it goes. I'll mull over the things you guys have said and try a new tact.
    The battery, although it could be an issue, I don't think it wouldn't be from dealer showcasing. The odometer had 2 miles on it the first time I took it for a test drive and 20 mi on it when I drove it off the lot. I will check to see how long the engine takes to shut down at stops as suggested.
    F8L, our prayer has been answered. The tires are the Bridgestone EL400s so I'm taking that as a good thing. As far as the wheel size goes I might expect a mile or two hit on MPG from the 17 inch wheels but I'm going to have to question an 8-10 MPG hit.
    One more quick question... I have a short trip to take today ~75 miles each way. I have the option of jumping on the freeway (65-70 MPH) and go that way or take the scenic route with stop lights every couple miles and speeds of 40-55 with a shorter distance on the freeway. In the world of Prius, which is best for gas mileage? Form what I've read the scenic route is best??
    Thanks for your info.
  5. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Absolutely.
    My daily commute gives me the choice between 23 miles all freeway (including a mile or so surface streets at each end) or 20 miles at a slower speed (mostly 45-50 mph of Woodward Ave) of which about 6 miles is freeway at one end. I reliably will get 5-7 mpg better on the second route.
    If you opt for the freeway you'll do noticeably better at 65 mph than 70 mph but you might not be comfortable travelling much slower than the general flow.
  6. oldgoat99
    Spring, TX
    Thanks again. I'll post back as soon as I get more info on my next couple tanks.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Interesting. I had not seen the Bridgestones offered as an OEM option for the 17" wheels. I don't know what to expect in terms of mpg with those tire.
    The OE Toyo Proxes A20 incur a 1.5-2mpg hit it seems and the Primacy MXM4 is about a 3-4mpg hit. All compared to the OE 15" tires.
    You don't mention your usual commute. How many miles do you drive per trip?
  8. walter Lee
    1,126
    376
    Maryland
    Chris is correct
    1. Do not use B mode stay in D mode.
    2. Do not use ECO or EV mode
    instead use Normal or Power mode.
    The Regenerative braking normally recaptures about 10% to 40% of the braking energy the rest is lost as heat - it is a lossy power conversion. Even more so than with the Honda Civic Hybrid, it is more energy efficient to slowdown the Prius gradually without using eithe the regenerative brakes or the hydraulic brakes.
    Recharging a depleted HV battery via the gas engine is not energy efficient. In stop and go traffic jams that is likely to longer than 5 minute use the gas engines and avoid using the electric motors.
    On flat roads, the electric motors work to assist acceleration at speeds under 25 mph. However, if the Prius is going downhill whill accelerating the the electric motors can accelerate the Prius has high as 45mph before the ICE jumps in.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    "I do use the "B" mode on the shifter when I see traffic slowing and go back to "D" for normal driving"
    Just keep it in Drive...slowing traffic IS normal driving. I don't know why you would think you need to shift it into B for slowing traffic.
    My understanding is "B" is suppose to be used very rarely, on long descents down hills or mountains.
    patsparks likes this.
  10. oldgoat99
    Spring, TX
    I don't have a "usual commute". Some days I don't leave home, other days I go various places. About the only places I go on a regular basis I take my other car and the Prius is left for my wife to go someplace if she wants.
    ok, I promise to never use "B" ever again for coming to a stop.:p Still not sure about not using eco mode or not and I see no value in PWR mode for normal driving. Although. I do miss the 436 HP of my other car at time when I'm in the Prius. :LOL:
    So, before I left on my 15 mile trip yesterday I reviewed Bob Nagy's video. I went from Spring to Galveston to Kehma and back with three 5 stops along the way. I took the scenic route with no freeway driving except for a couple mile crossing the bridge to Galveston and then about 40 miles of congested (5o-60MPH) freeway on the way back. I started the trip with about 140 miles on the current tank of gas and filled up when I got back so I could get a reading on my first tank of mostly city driving.
    As you can see the mileage for my trip was much better that my other tanks which were mostly highway driving. And for the first time I was able to "relate" to the information in the video. It acted exactly how I thought it should. Driving at highway speeds and short distances in the city was not giving me the feedback I thought I'd be getting. So, I guess everything is cool now if I can just figure out how to get the highway mileage up. Maybe I just have to go up the learning curve a little more. If you notice, line 6 in the graphic shows an increase in MPG. That is the tank where I switched from normal to ECO mode about a quarter way through the tank.
    Thanks for all your help. I still have a couple thoughts but I'm out of time here for now. I'll try a few more things from your suggestions and let you know how it goes.​
    Thanks again,​
    Gordon​
  11. bisco
    51,996
    well done! highway is tough, mostly related to speed.
  12. Former Member 68813
    3,524
    983
    US
    When I drive, I get 55-60 MPG (indicated, suburban/city only) and I'm usually one of the faster ones on the road (limit+10MPH). When a family member drives it, exactly 40 MPG (again, indicated). It's all about the driving. I always watch HSI to accelerate fast and as short as possible and coast as much as possible.
  13. walter Lee
    1,126
    376
    Maryland
    While its well known fact that higher the speed reduce fuel efficiency - there is some other factors at play that can change overall fuel efficiency.
    This year while studying hypermiling at superhighway speeds I learned that one of the key factors in getting good fuel efficiency (high MPGs) is to avoid a rich/saturated fuel mixture while still going fast enough that you are not impeding traffic (the ScangaugeII xgauge LOD is suppose to identify when the ICE is using a rich/saturated fuel mixture). This however is only half the story since the fuel mixture represents only the how efficient the energy demand rate is and does not equate to how efficient the final output of the engine is. That is to say - how hard you have to run the gas engine to get a certain speed is dependent on the timing of when you press the accelerator to gain or maintain momentum/speed which dependent on variations in the output efficiency of a motor vehicle due to changes in the speed, elevation, road conditions/surface , weather, and traffic. There is a balancing act of sort between demand efficiency (when the Prius power plant operates most efficiently) and output efficiency ( when the driving conditions allow Prius gains speed/momentum more efficiently). At superhighway speeds both the Prius and the Civic Hybrid rely more on their gasoline engines-transmission and aerodynamic design (which are approximates if not in the same class) than their hybrid tech. High Speed negates most of a hybrid's advantages so that the biggest factor in getting the best fuel efficiency ends up being the driver and not the car.
  14. briank101
    briank101 Member
    170
    68
    Western Chicagoland
    I thought gen iii didn't do fuel enrichment, unless cold or maybe when near the rpm red line.
  15. prius_in_pa
    prius_in_pa Junior Member
    208
    27
    On freeways, I could easily get 55 to 60 mpg. On local roads with low speed limits, I could get as high as 70 mpg. Of course, in order to get high mpg, I had to put the car in "Eco" mode and take it easy on the gas pedal. Furthermore, I also use pulse and glide even on the freeways whenever there's no cars behind me. Gliding on the freeways is less efficient than on local roads but still will save you gas. I generally like to glide below 40 mph, that's when the computer stop the ICE from turning completely. When you're gliding above 40 mph, the ICE will turn even though no fuel is fed into it. Having the ICE turning will increase drag and as a result, you wouldn't be able to glide as far.
  16. walter Lee
    1,126
    376
    Maryland
    The 3rd gen Prius burns quite a bit of fuel during warm up(to heat up the catalytic converter) and when the HSI display is in the Power area. The 3rd gen Prius liftback is a very heavy at +3000 pounds and require quite a substantial amount of power to accelerate quickly especially on hilly terrain ( because a Prius c is lighter this is less of a problem and because the Prius v is heavier this is more of a problem). Because the Prius' electric motor's ability to assist in acceleration is limited mainly at lower speed except when going downhill (this is due to the NiMH battery pack which can't provide enough current/power - this electric power limitation is less apparent on a Plug in Li-Ion battery pack) - accelerating quickly and hard over 30 mph will cause the Prius' Atkinson Cycle ICE to burn more fuel. Accelerating the Prius for any extended time period in the POWER (rightmost end) of the HSI display (>= 2.00 gallons per hour , >= 2000 Revolutions per minute ) is normally very inefficient
    The hypermiling technique I am using modulates the accelerator pressure so that the ScangaugeII xgauge LOD needs to be more often than not between 70 to 80 percent . When doing this the RPM and GPH will vary widely depending on the speed of the car and the grade of the road, but the combination energy usage meter HSI display is normally slightly to the left of the "ECO" capsule to right dab in the center of the HSI display.
  17. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Weird.
    My wife is avg. 45+ in our GenII.
    I'm avg. 55 in our Gen III.
