Keeping EV battery 40% full?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Troy Heagy, Apr 24, 2013.
  1. stanwagon
    stanwagon Junior Member
    64
    2013 Prius Plug-in
    As always, very helpful... thanks Dr. I. The "even if stopped" comment is helpful since that seemed mysterious. Maybe I can try to not charge fully, though that does take a bit of fussing.
  2. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Forgot to include the link to a whole thread on the subject
    Living on top of a hill | PriusChat
    Maybe some other useful ideas there.
  3. bisco
    52,421
    if you're interrupting the warm up cycle, you may be damaging the system, i'm not sure tho. one of dr. i's solutions above is a better way to go.
  4. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    The Classic model performed housekeeping (engine startup after parking to cleanse/purge emissions). We were told by an engineer interrupting that process was fine. It would simply pick up where it left off later. Good thing too, since that was really annoying having the engine sometimes run upon arriving in my garage. Nothing ever came up as a sign not to either.
    So, I feel quite comfortable stopping the engine prior to warm-up completing with the PHV. It happens on a regular basis, running out of electricity just shy of my destination and when I move the Prius to a spot for plugging in.
  5. bisco
    52,421
    thanks john, and no issue with the rough start syndrome?
  6. drinnovation
    2,027
    586
    65
    CO
    I would expect stopping the engine when it starts is mostly about water and other contaminates in the oil, and only secondly about unburned fuel in the cylinders. For the oil it might be an issue if you keep doing it for weeks and never run the ice to full temp (which burns off water and helps filters out the contaminates). For a PHEV with a large EV range, like the Volt or CMAX, I can see that being more an an issue but not for the PiP -- chances are very good you'll run the ice with a day or so.
    Water in the oil is mostly a long-term reliability thing, nto a rough start. Rough start might occur be from leaving unburned lower-quality fuel in cold cylinders that then slow evaporates leaving residue on parts. So it may also be function of the quality of gas, local humidity and how quickly you kill off the engine.
  7. john1701a
    12,833
    5,310
    58
    Nope. That's a nice side-benefit of E10, something we've been taking advantage of since the 90's here in Minnesota.
  8. bisco
    52,421
    so, people without e10 might have problems?
  9. 3PriusMike
    3,101
    2,419
    Silicon Valley
    I regularly go a week or so without running the ICE. I get the ICE coming on, automatically, because I've gone 124 miles without the ICE every so often.
    Mike
  10. drinnovation
    2,027
    586
    65
    CO
    Yep.. Volt allows 6 weeks between EMM. If you shut off when it does the start, does it automically retry on the next start (the volt does). Water accumulation for week or so is not that bad.. its for months where it reallly because becomes an issue.
    E10, with respect to water, is both better and worse . Ethanol is more hydrophilic (attracts more water). It does ensure the water will not freeze (which is good in MN) but in general increase overall water content which if the engine sits too long is bad.
  11. john1701a
    12,833
    5,310
    58
    Don't forget that Prius doesn't shut off the engine until it has reached a state where it can remain that that way for an extended period. So, starting it to run only briefly won't be like a traditional car that is just abruptly stopped without any prepartation.
  12. Troy Heagy
    Troy Heagy Member
    1,218
    After just one year I rusted-out a catalytic converter on my first car because my 2 mile trip was too short. Driving it every day did not prevent it from happening, and the mechanic said both the engine and catalyst have to get HOT in order to thoroughly-evaporate the water.
  13. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    I heard someone call it an executive decision too. In the end it probably was much like any decision made. I believe it was from a podcast with Chelsea Sexton saying it. I swear 90% of what you have called fictitious was on podcasts or audio interviews from way back that I've heard as well. Like the diesel prototype of the Volt. Or even the fuel cell version.
    iPad ? HD
  14. Troy Heagy
    Troy Heagy Member
    1,218
    Diesel prototype of the Volt? They should have made that. It would increase its fuel economy another 10 MPG (the difference between a gas jetta and a diesel jetta). Maybe more
  15. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    While many of us like Diesel, I think the perception of having to pay for an even more expensive fuel (Diesel seems to be more expensive than Premium in my area) than what the Volt requires now might not go over well with the general public. Yes, I know Diesel offers more energy/BTU, but good luck explaining that.
  16. Troy Heagy
    Troy Heagy Member
    1,218
    That's odd. When I refuel my diesel beetle, the per gallon cost is less than the supreme gasoline the Volt uses. (And of course the Beetle gets 50mpg, so it's also less cost per mile.) I would think Chevy releasing a Volt that gets 50mpg would give it bragging rights.
  17. drinnovation
    2,027
    586
    65
    CO
    If you, John or anyone want to make statements about what other people have said it would be nice to have sources so we can decide the reliability/authenticity of the source. It would not surprise me if there are podcasts from media folks presenting their views on "why" such decisions were made. Media musing on causes is just their guessing. But I've not even see that evidence.
    Chelsea Sexton had no formal role in the Volt development and it is unlikely she had any is any inside information on such decision As an outspoken community member and blogger she was added as a "community Advisory Board" (e.g ) long after such decisions were made. Given her professionalism I would still consider it unlikly she would have said, what John was alluding to that the lack of hold mode was "too much like a prius". She did write about Volt Mules related to a prius. She writes “in range extended mode- the thing is already Prius quiet.” I've listened to her on this podcast at Priuschat where, e.g.m she said The Volt is the best PHEV of all the one she seen and she explains its better for her than C-max or PiP. But I did not her say hold mode decision was at all related to a prius.. So if it was a pod cast from her any ideas which one. And either way it means, at best, it is her views. But its hard to fight against vague unsubstainated claims like John frequently makes (and for which he vary rarely provides support when challenged), maybe because it is frequent for people to misremember such things and filter what they hear/see with their bias.
    There was no diesel or FC "volt", though there concept cars described as Diesel E-FLEX (the name for the underlying platform in the early days) Frankfurt Preview: Opel E-Flex Concept - Carscoops and
    Fuel Cell E-Flex (Shanghai Motor Show: GM unveils fuel cell E-Flex). When a company shows a concept it may or may not lead to a product (more often not).
    Overall what is your fuel costs per mile? My volt is at $.026.
    Yes YMMV and you may occasionally get 50mpg on your beetle, just as I get it on my volt when I use gas at all.
    EPA for the Diesel Beetle (automatic) is 29 City, 39 Highway/ 32 combined.
    The volt (when using gas) is 35 City, 40Highway, 37 Combined.
    So the Volt already blows a beetle away when on gas (by EPA). Furthermore gas is very infrequent for most drivers, with the voltstat median being 169 miles and average over about 21Million miles, being 131 MPG. Having a 40ish mile EV battery for most trips greatly reduces the demand for gas.
  18. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Nope not important. I've heard it before but not from John. Didn't believe it then but it just wasn't important enough to challenge. In fact it got a chuckle from me if anything.
    iPad ? HD
  19. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Hmmm, my commute is less than 3 miles and my Gen II Prius never had a problem with moisture. Rusted out a muffler, twice, on my truck but not the Gen II Prius.
    Now all the mechanics that work with my wife (DOT), tell me the gas in my tank is going to go bad.
    iPad ? HD
  20. Troy Heagy
    Troy Heagy Member
    1,218
    People like you annoy. We cannot have a conversation w/o someone like you saying, "My car is better and your car 'blows'!" First off: 2.6 cents/mile? That's about 260 watt-hours/mile which I find highly improbable. (Too low versus the EPA's official 360 rating.)
    Second I was not claiming my beetle is better than your volt. I didn't buy the beetle to save fuel (that's what the 70mpg insight is for). I bought it for how it looks. Furthermore everyone knows EVs and hybrids are more efficient than standard cars, including me.
    I was saying the volt would be an even better product if it used a high-compression, high-efficiency engine to recharge the battery. i.e. A compression-ignition engine aka diesel. There's a reason why trains and ships use these engines rather gasoline engines: It saves money and energy. The Volt on diesel would be more energy-efficient than a Prius (MPG over 50).
    BTW the volt wouldn't really work for me. I drive close to 200 miles a day, so I'd be seeing a little over 40mpg overall (the highway rating). None of the current EVs would work either due to limited range.
