2012 or newer HU replacement
Discussion in 'Gen 3 Prius Audio and Electronics' started by hbpb, May 7, 2013.
  1. hbpb
    hbpb Junior Member
    Has anyone replaced the 2012 HU and retained all of the steering wheel controls? If so ...., well how do I do this?
    I did a search and couldn't find a definitive answer.
    Thanks.
  2. tach18k
    tach18k Member
    406
    SoCal Beach Area
    when you replace the HU, you will lose some stuff, that stuff is some of the car data features. You can use the audio controls via special connectors manufactures have made for this purpose. Each non Toyota HU should come with them or bought separately.
  3. hbpb
    hbpb Junior Member
    I understand this, but the trip and display selection (right side of steering wheel) now goes through the HU on the 2012 and newer. I was hoping to hear from someone who has replaced their HU and retained these controls.
  4. tach18k
    tach18k Member
    406
    SoCal Beach Area
    I think you still have control over those functions, but only on the heads-up display and not the HU radio's screen.
  5. hbpb
    hbpb Junior Member
    So I can still change the top display, select trip a or b, etc using the steering wheel controls on the right side of the steering wheel?
  6. tach18k
    tach18k Member
    406
    SoCal Beach Area
    Yes I think that is correct, the left steering wheel operate the audio. The right controls will still work on the dash display.
