Security Triangle comes loose in trunk, solutions?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Solar Hydro, Feb 2, 2006.
  1. Solar Hydro
    Solar Hydro New Member
    42
    Hello all,
    I am a satisfied Prius '05 driver, in Europe (avid 'EV mode' user in parking lots, on business parks, small roads and passing through small villages, and demo-ing ;-)).
    The most irritant (but perhaps trivial) issue that I have with the car is that the security triangle (which, hypothetically, you would put on the road to signal other cars about a broken down Prius), rattles like mad in the trunk.
    It is located under the trunk cover, is encased in a red plastic box, and is vaguely, but inadequately positioned in a plastic molded 'compartiment' that is basically the lower part of the trunk.
    When it rattles too much, I put it back in place, rattle goes away, but after a couple of weeks the rattle invariably comes back, and after a third or fourth week it starts sliding back and forth loose in the trunk when taking turns, smashing from left to right.
    Is anyone else experiencing this? (no idea if these triangles are mandatory in all countries), and if so, has it been solved?
    I am about to resort to radical measures, which could include: throwing the triangle out (probably illegal), throwing the casing out, to see if it fits better, and taping down either the red box, or the triangle without the red box.
    Suggestions most welcome!
    Thanks
    Solar Hydro
  2. aaf709
    3,862
    2022 Prius Prime
    It's not required in the US, but I have a question. Is the rattle coming from the box rather than the box itself? I mean, is the triangle secure in the box and/or the box secure in the niche? I'd put some sponge foam pieces to help wedge it in place. I did that when my old car started to rattle.
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    hmm. interesting. we don't have those in the US. or at least i didn't get one with my prius.
    so is the case rolling around the storage area or is the triangle running around the case? or both?
    how about lining the container with a small handtowel or something to keep the triangle in place... for the case... i haven't really seen what the setup is to suggest anything to keep that thing in place.
    good luck :)
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
  5. kaizen
    kaizen Junior Member
    Little Rock, AR
    The warning triangles don't come with U.S. Prii, but Velcro strips sometimes work well for fixing problems like this. Let us know what solution you come up with.
  6. Solar Hydro
    42
    Thanks all,
    I'll experiment some solutions this weekend, and perhaps post a picture.
    Solar Hydro
  7. Solar Hydro
    42
    Hello all,
    I have now (hopefully) addressed the irritating security triangle problem.
    Background: the security triangle's box tends to come loose in my Prius' trunk. It first starts rattling and eventually ends up bashing around while driving.
    This may indeed be a European/Belgian-only problem, because while working on it, I noticed that the plastic box of the security triangle contains an inscription: 'Selected by Toyota Belgium'.
    I opted for taping the box down with double-sided sticky tape, and putting pieces of foam on either side, in the hope that it will now be firmly kept into place. I have not driven yet. I'll report back here only if my solution ends up being unsatisfactory...
    You may wish to examine the 'before and after' pictures (which also reveal some of my favourite Belgian beers) via:
    Solar Hydro's Prius Pictures
    To see the details, first click on the thumbnail, which shows only a slightly bigger picture, and then select 'all sizes' in the options above the pic to see full details.
    The key 'solution picture' (I hope this will hold) is this one:
    Prius Security Triangle Solution?
    Solar Hydro
  8. KMO
    KMO Senior Member
    1,942
    672
    Finland
    2023 Prius Prime
    I've got a similar triangle box (purchased by myself). My solution to that compartment was to buy the rubber mat that Toyota sell for it. It's a carefully shaped mat that fits neatly covering the whole of the base of the compartment, concealing the tools. It's non-slip, so the triangle basically stays put.
  9. KMO
    KMO Senior Member
    1,942
    672
    Finland
    2023 Prius Prime
  10. KMO
    KMO Senior Member
    1,942
    672
    Finland
    2023 Prius Prime
    PS - that triangle looks a bit poor. It clearly doesn't meet UNECE R27 specifications. Hope that's not compulsory in Belgium. (In the UK we're not required to carry anything...)
  11. Zacher
    Zacher New Member
    236
    OR
    Non-skid area rug backing wrapped around the offending object works quite well, too.
  12. Solar Hydro
    42
    Heh, I'm not going to un-tape it to check! I didn't fully 'assemble it' for the picture, I just put the triangle in its form (without clicking pieces into exact position) and put it against the rear bumper to take the picture, given that previous posters did not seem to know this device. It has 3 little feet to create a tripod etc. and you're supposed to put it far enough away from your broken down car to alert other drivers in time.
    Thanks for comments. I find it hard to believe that a mat would keep it into position.
    Solar Hydro
  13. KMO
    KMO Senior Member
    1,942
    672
    Finland
    2023 Prius Prime
    Works for me. The mat's totally smooth, flat rubber on the top, and pretty sticky. My triangle box is flat enough and heavy enough that it doesn't seem to go anywhere. But it probably would if I drove roughly enough.
  14. priusNlondon
    priusNlondon Pingu 2.0
    49
    Somerset, England, UK
    ----UK----
    might i suggest using the velcro tape instead of the double sided tape? that way when you actually need to use the triangle you can remove it easily?? they have double sided magnetic strips as well. you can find them in office shops (Staples or Office Max) or in a fabric store with sewing and craft materials. if you have trouble i can hunt some down for you online in the EU area. :)
  15. Solar Hydro
    42
    Thanks for the suggestions and offer. I'll stick with what I have for now; it's not as if I expect to ever use that security triangle repeatedly. If the day comes I'll just rip it out.
    Is the velcro you mention a sticky tape on one side and velcro on the other?
    Solar Hydro
