Flashing gas gauge and transaxle frames
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jgavis, Jan 31, 2006.
  1. jgavis
    jgavis Junior Member
    Seabrook, Texas
    I have a late 2005 Prius, Package 2. After driving 3.5 miles to work and parking for 9 hours, I got in the car (smartkey worked) held the brake pedal, pressed power. The dashboard lights came on, flashing 1 bar of fuel <_< (should have been 3), but the LCD didn't come on. There were some clicking sounds coming from under the hood. Power windows were sluggish, lights were dim like a low battery. The gas gauge begins flashing all 10 bars at the same time that all frames of the transaxle begin flashing. :blink:
    I press the power button again and the dash lights flicker for several seconds then go off. I opened the door and the car started beeping at me until I closed it. I checked and I didn't leave any lights on or doors ajar anywhere. The manual only mentions the transaxle lights flashing and says to take it to the dealer. The dealer said over the phone that they'd have to take a look. I arranged a tow under warranty, and kept trying to start it now and then.
    After about ten tries and 30 minutes, it finally started up with the exclaimation point :eek: and the LCD activated, saying something like "There is an abnormality in the position of the transaxle. Safely park your car on a flat surface and fully engage the parking brake. " The parking brake was already completely engaged, and the message timed out and the car turned off. I turned it on again and it worked like there had never been anything wrong. :lol:
    Upon driving the car to Toyota with a detailed written description of events (which they said they really appreciated), they checked the battery, error codes, everything they could think of, and there was no sign of there ever having been a problem. No messages were logged in memory.
    Has anyone else had a similar problem, or know why this may have happened?
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    from what i understand some codes (but not all) can be cleared from memory after a whole bunch of restarts. some require a certain cycle to be completed before they're cleared.
    we've seen prii do some extremely strange things because of low batteries/bad connections.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Interesting problem. Any chance you might have left a light on or something for the 9 hours it was parked and run the 12 volt battery down?
  4. Liam
    Liam New Member
    96
    I got this message once. It was when I pulled off on the side of the road and got out of the car with the fob and left the car running and the door open. (I had to save a turtle that was in the middle of the road) There were no other blinking lights, but I had to turn the car off and start again before I could put it in drive.
  5. KTPhil
    KTPhil Active Member
    1,379
    22
    "all frames of the transaxle begin flashing."
    What on earth does this mean?
  6. joelparks
    joelparks New Member
    82
    Bedford, MA
    ya know, P for Park in a box (frame), R for reverse in a box, N for Neutral in a box, D for Drive in a box, B for brake in a box, all at the same time. On the speedo panel display not the MFD.
    zat help?
  7. naterprius
    naterprius Senior Member
    1,843
    Your 12 volt system is likely malfunctioning! I left my car in the "ON" position for the better part of 2 days and this is what happened to me when the battery got low.
    It is also possible there is a bad ground with the 12 volt system.
    Have the dealer do a charging and drain test on the 12 volt battery.
    Nate
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I noticed that it might be the 12v system too. When i was listening to the radio for about 3 hours. when the car was "dead" everything flashes.. drive it around for a half an hour.. or at least 20 mins.
  9. jgavis
    Seabrook, Texas
    Thanks for the input. It is possible that the headlights remained on while I sat in my car for lunch. I don't know if they time out or stay on until you open the door (if you leave them in the on position, of course). The dealer's certified Prius tech looked at the car for an hour (actually taking it in to work on it as soon as I got it there) and said they 'tested the battery' as well, but I don't know if that was a drain/charge test.
    Since the windows were sluggish and the lights were dim, I'll assume it was a low battery probably due to something I did. It's nice that it bounced back enough to start.
    Thanks again
    B)
  10. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
    I repair collision damaged Prius's and have seen this condition many times. First check the fuses under the hood. ( well in your case it was probably a low 12v battery), Second place the car in neutral and rock it back and forth, then push the park button.
    3rd get a voltmeter and check the fuses under the hood again ;)
  11. marcdare
    marcdare New Member
    51
    Los Angeles
    <div class='quotetop'>QUOTE(jgavis @ Feb 3 2006, 10:18 AM) [snapback]203134[/snapback]</div>
    Hey Jgavis, I like your homage to Centauri's car from "The Last Starfighter."
