Side panel removal
Discussion in 'Gen 3 Prius Technical Discussion' started by cmc5dc, May 10, 2013.
  1. cmc5dc
    cmc5dc New Member
    What is the easiest way to remove the panel where the light dimmer is located. I wanted to access one of the slots to put a dummy LED flashing light for deterrence purpose. Any help would be appreciated.
    2013 Prius II
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    An illustration:
    There's a screw to be removed at the lower left corner before you start working with these latches. Also may have to deal with the hood release cable once things are initially undone.
  3. cmc5dc
    cmc5dc New Member
    Thank you
  4. El Dobro
    El Dobro A Member
    7,088
    3,270
    No flashing padlock on the dash?
  5. cmc5dc
    cmc5dc New Member
    If you've had your car broken into than anything to deter a thief would be smart. ;)
  6. El Dobro
    El Dobro A Member
    7,088
    3,270
    I had the roof stolen off of one one of my Vettes and the alarm didn't do squat. Does that count? ;)
    The Prius already has an "armed" light that flashes on the dash. If that doesn't scare them away, another one won't either.
  7. cmc5dc
    cmc5dc New Member
    If you have nothing informative to add, please don't comment. Just think, if you had a question, you would want an answer to your question...you offer nothing of the kind.
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    And I asked you if you had the flashing padlock on the dash because, a. some don't know what it is and have asked in the past, or b. maybe the 2013 doesn't have it, and you didn't answer my question. See ya.
