e-cool would work in a Prius?
Discussion in 'Gen 2 Prius Audio and Electronics' started by petteri, May 26, 2004.
  1. petteri
    petteri New Member
    203
    Plantation, FL USA
    I came across this today:
    http://www.exciters.com/0009/ecool_AFT1.htm
    Would it work in a Prius with its small regular battery? Not to mention the complicated computers controlling everything...
  2. Brian
    Brian Member
    480
    Bakersfield
    I wouldn't get it, you can just roll down the windows for a minute and then put them back up and it is cool.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Unless it's 115F outside in the desert... :)
    I wouldn't get it w/o a solar panel to power it though, the Prius 12V battery is pretty megar when it comes to longevity.
    I'd consider first the deal that fits into the window, and is a solar powered "fan" that keeps the car ventilated.
  4. Brian
    Brian Member
    480
    Bakersfield
    I have thought about those fans before, but here around OC it doesn't get that hot. We can do without it. :D
  5. tochatihu
    tochatihu Senior Member
    9,765
    3,765
    Kunming Yunnan China
    2001 Prius
    I received one of those as a birthday present. It is an "Autoveturbo", manufactured in the UK. It is helpful in the parked Prius, but at highway speeds it is too noisy for my tastes. I would use it for extended summer driving at lower speeds, however, so mine is not for sale.
    DAS, and Tochatihu, a 2001 with 59k miles, 46 mpg mostly driven in So Cal
