How to get max power in Prius?
Discussion in 'Gen 3 Prius Main Forum' started by Troy Heagy, May 15, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    I was watching a review on youtube where a Prius and pickup were running at 75. The Prius tried to pass the pickup, but the pickup driver accelerated and blocked the action. The insight and civic hybrids have a way to "downshift" which redlines the engine for max power......... does Prius G3 have anything like that?
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    At 75 mph the Prius goes to peak power rpm automatically when you floor it.
    Redline is past max power rpm on nearly all cars. If you are redlining the engine, you are producing less than max power.
    F8L likes this.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    The interstate here has a speed limit of 75mph. I routinely drive at 80mph.
    I do not see any 'need' to pass anyone at those speeds.
    I do pass other drivers who are driving slower. But why pass someone who is already exceeding the posted limit?
    CaliforniaBear likes this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The software attempts to give you the power (in most cases, actually torque) you request with your right foot.
    The HSD (Hybrid Synergy Drive) or PSD (Power Split Device, the hardware the computer's software is controlling)
    Toyota Prius - Power Split Device These is a nice Gen 1 Prius simulator down the page a bit. Actual details will vary, (Gen 3 has a 5200 RPM red line for example) but the principles are the same.
    M/G2 (Motor/Generator) is geared right to the wheels, so as you rev M/G2 you can select 70 MPH.
    You will notice that the line connecting M/G2, the ICE (Internal Combustion Engine) and M/G1 'breaks' and turns red. This is because you can't go 70 MPH with out turning on the ICE, so lets rev it up to about 1300 RPM so the line is not 'broken' and red.
    Now you can play and see that by altering the ICES revs between 1300 RPMs and red line, M/G1 varies between 6500 RPMs turning the same way as M/G2 and the ICE, to 6500 RPM going the other way. (The software actually controls M/G1s RPMs and the throttle for the ICE, your foot on the accelerator is just a suggestion)
    On my Gen 2 I could see the ICE rev with an accuracy of 6 RPMs, that is a lot of choices. If the ICE can make the power, the HSD can find it. In my Prius,a constant 70 MPH on a flat road is near 2050 RPM. Different models and generations will vary.
    Electric motors often produce maximum torque at 0 RPMs, sl it helps the Prius at low speeds a lot, not so much at high speeds. (This is a generic curve, not the actual Prius M/G2, the starlight line is torque, the curved line is power))
    I suspect the Prius ICE is artificially held to a low red line, the Otto equivalent engine has a red line of 6000 RPMs as an example.
    Toyota ZR engine - Wikipedia, the free encyclopedia
  5. Troy Heagy
    Troy Heagy Member
    1,218
    I thought it was well-known the Prius has an artificial redline. The very first Prius (japanese model) was only 4000rpm in order to reduce consumption, not because it couldn't spin faster.
    Only slightly. Redline in a Honda Insight is 6000 and the power peak is at 5800. When you "downshift" the CVT it automatically moves the engine to that peak power for max acceleration.
    Also there are zones in the U.S. where speed limits are 80 or 85, and traffic moves about 90.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The Gen 2 and 3 Prii don't put out any more power if you spin them faster, so no point in spinning them faster.
    That is part of the reason I said "nearly all cars".
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Gen3 ICE max out at 5,200 RPM. The only way to get rev that high is with your right foot.
