Spark plug replacement - tools needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tomiha, Jul 7, 2008.
  1. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Could be real or could be imagined. If it is true then your engine would have to be operating more efficiently, so I'd expect to see a noticeable increase in MPG too. So to be honest, unless you also notice a corresponding MPG increase then it's probably "all in your head".
  2. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I'll let you know. I just changed them yesterday. You wouldn't believe the rust I had on the top part of the plugs and threads. No more engine wash-down for me.
    DROID RAZR ? 2
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah, that little "channel" in the top of the valve cover really is a nice trap for water isn't it. I used an funnel with an over-sized opening to fill the oil one time and accidentally filled that space up with oil. :confused:
  4. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I just got the chance to drive on the highway and I can without a doubt tell you that there is a huge difference in acceleration. It feels more powerful and "brisk". Like the car is new again. I currently have 87.5K miles. I just wanted to change the plugs early and now I'm glad I did.
    The water damage to my plugs may have affected its performance. Who knows.
    DROID RAZR ? 2
    Fostel likes this.
  5. unmesh59
    unmesh59 Junior Member
    49
    SF Bay Area
    The roads slope up to our house and I noticed it too. On the other hand, the fuel economy has not gone up.
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
    You guy's are making me itch to change out my plugs now. :)
    I've got a new set here ready to go, but I've been waiting for my 200,000km (125k mile) service to do it. Currently I'm at 175,000 km.
  7. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Do it! Plugs are cheap. I went with the factory Denso. Use a torque wrench and do not use anti-seize.
    DROID RAZR ? 2
  8. 04prius123
    04prius123 Junior Member
    Thank you everyone very much for sharing your experiences. I changed my plugs yesterday with that special advanced auto magnetic spark plug tool without removing the cowl. I felt this job was easier than changing the oil for me. My Prius has 128k on it and the plugs were worn but not that bad. I don't think it was urgent for me to change it. I don't think I feel any performance increase or anything after changing the plugs. But I also don't feel any change after changing the oil. Thanks again.
  9. jefe
    jefe Member
    169
    Cary, NC
    I also just changed my plugs thanks to all of the great advice in this thread. I picked up the magnetic socket from Advance and it made it super simple. Took me 40 min including cleanup.
    One thing I noticed is that the existing plugs were NGK. Does that mean they had been changed before? I'm at 141K, and I bought the car with 100K.
    Here are a couple of photos:
  10. jefe
    jefe Member
    169
    Cary, NC
    BTW.. Advanced sells the Denso now ($9) but I went with NGK ($7)
  11. Patrick Wong
    18,200
    6,492
    NGK and Denso both provide original equipment iridium plugs to Toyota for the Prius. The old plug in your photos had accumulated sufficient deposits so I would say it had not previously been replaced.
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Other than the slightly rough appearance from the deposits, the electrodes look very well shaped. That makes me wonder whether the plugs can still be used for a very long time.
  13. jefe
    jefe Member
    169
    Cary, NC
    I wasn't experiencing any issues, just did it because, well it seemed like I should.
  14. Pink5owen
    Pink5owen New Member
    Oh my, wish me luck ill do mine tomorrow morning ( feeling nervous)
  15. Pink5owen
    Oh my, ill do mine tomorrow morning... Wish me luck! ( feeling nervous)
  16. Pink5owen
    Hi! May I ask, why not use anti seize? I'll be replacing mine tomorrow morning..
  17. Aaron
    Aaron Member
    260
    Monroe, Ohio
    It's not really necessary as the threads of the plugs are already plated. Also, anti-seize can fall into plug hole. I didn't use it.
    DROID RAZR ? 4 Beta
    Pink5owen likes this.
  18. 2009Prius
    2,705
    511
    63
    Check the plug manufacturer web site. Some manufacturers specifically recommend not to use anti-seize on some plated plugs.
  19. Pink5owen
    I'll be using ngk laser iridium 4996.
  20. 2009Prius
    2,705
    511
    63
    Attached an old PDF from NGK.
