Remote A/C System
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 20, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    I am looking into a base pip in NJ and here is what is listed on the spec sheet. I wonder if someone can shed some more light on exactly what this is...
    Auto Climate Ctrl Sys w/Remote A/C Sys
    Thanks!
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    It's like remote-start except for a/c. Get it cooling down the interior before you get to the car. I had it on mine as part of the solar roof package. FOB range was limited.
  3. DU3L NRG
    DU3L NRG Junior Member
    37
    Cools your car before you get in. It stays on for 3 mins, or earlier if the battery gets low. (But battery shouldnt be an issue for PiP) the button to start it is built into the key fob
  4. CharlesH
    2,797
    1,164
    Roseville, CA
    This feature with the key fob is distinct from another one that offered only on the Advanced, which allows you to turn on the A/C from a smartphone.
  5. markabele
    5,084
    1,782
    Nebraska
    This is great! I didn't expect this on the base model. Will it worked even while plugged in?
  6. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yes. It will stop the charge (if it is charging) while the AC is running and then resume charging once it stops.
    What I havent tried myself is to engage the Remote AC if the car is plugged in and fully charged. I would assume after the AC shuts off, it'll top it off again. But like I said, I havent seen it for myself and I dont recall the manual mentioning that particular scenario.
  7. markabele
    5,084
    1,782
    Nebraska
    Will be a fun thing to try whilst getting free electricity sometime.
  8. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I haven't tried this, but I don't think that's how it works based on my experience below. I'm pretty sure charging does not stop.
    When you do this, the car starts charging and the A/C is running off the plug. If the A/C is consuming more power than the plug can supply, then it drains the battery a bit, which causes charging to continue after the A/C shuts off.
    markabele likes this.
  9. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Here's what the manual says, if it makes a difference
    usbseawolf2000 likes this.
  10. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    It runs for 10 minutes. Here's screen samples of the phone interface...
    [​IMG] [​IMG] [​IMG]
  11. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Neat feature I doubt I'll ever use. I'm sure there are hot spots where it's a welcomed feature.
  12. john1701a
    12,820
    5,305
    58
    You'd be surprised how nice it is... and remember this thread when Summer heat arrives.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    I never used the feature from the fob on my 2012 Three but on the PIPa I use it all the time. It's so nice to be able to "call" the car while still inside the mall and have it precool the car. It keeps my SO happy. ;)
