  1. ProphetsOfDoom
    95
    93
    64
    Virginia
    Installed the Prius Plus body kit last weekend and finally got around to taking some pics. Steering wheel was installed today.
    ...and washed it just in time for the rain!
  2. FishCandy
    FishCandy Active Member
    220
    292
    Got the 5 Million Hybrid Sticker today, are you guys going to put it on?
    sfv41901 likes this.
  3. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I don't understand why they called it a "badge". A true badge would have been better. Hopefully we can find a place to put this.
    Kit Shah likes this.
  4. J Dunn
    J Dunn Active Member
    118
    169
    Newport Beach
    Dang it's huge...I ordered one too...now I'm thinking I'll put it somewhere other than on the car.
  5. Burna J
    1,065
    3,334
    53
    Long Beach, CA.
    Yep, that will go great on my garage window.
    Plus IV likes this.
  6. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    Car is at the body shop right now. Got side swiped in front of my house. Let me tell you how happy I am about that. Figured while it was there, it's time to do the '12-'13 front end conversion. It's not cheap, especially because mine is a package five but it's gonna look so good when she comes back home!! Will post pics when it's all done.
    sfv41901, Bullet Salvador and Dawit like this.
  7. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Where'd u guys get it?
  8. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
  9. bzyrice
    805
    324
    West Palm
  10. Sid Amameda
    Sid Amameda New Member
    Norwalk, California
    Bullet Salvador likes this.
  11. HAWAIIANBUILT
    HAWAIIANBUILT Senior Member
    824
    791
    69
    SO CAL
    AHA !!!
    We need to Pow Wow !!!
    Rodney
  12. SFR-DSR-44
    SFR-DSR-44 Junior Member
    59
    Milpitas, CA
    I installed clear bra material below the rear hatchback opening to protect against damage as things are stuffed into/dragged out of the back. I wanted a clear material, not the factory one with "Prius" on it, and couldn't find a pre-cut piece on EBay or Amazon or elsewhere. I ordered a 24" x 30" piece from RVinyl.com for $14.
    Procedure (There are probably easier/faster ways, but this was very step-by-step):
    Step 0: Liberally cleaned the bumper area with Mother's Showtime detailing spray.
    Step 1: Covered the area I wanted to protect with 4 layers of blue painters tape.
    Step 2: Using a long plastic ruler and the creases of the bumper, I marked the tape with a pen to outline the actual final shape of the protection.
    Step 3: Transferred the blue tape piece to a large piece of leftover cardboard, and then cut that out on the line lines I drew to make the template. If you only use 1 layer of blue tape, it will change shape and likely tear hence my 4 layers.
    Step 4: Placed the template over the bumper to check for fit. Since I actually wrapped it down the ~45 degree section as well, just not on the vertical, I couldn't test fit this part but trusted my tape job.
    Step 5: Then placed the template over the clear bra material and used a exacto knife to cut out the material.
    Step 6: Using a 25% IPA solution / 75% water, I sprayed my hands to get off dirt and grime (Don't forget this or you'll put finger prints on the adhesive of the clear film)
    Step 7: Using a 25% IPA solution / 75% water, I sprayed the bumper in the area I will apply. Check again for particles that may have settled in the area. Once it looks perfect, move to Step 8.
    Step 8: Peel the backing off the film.
    Step 9: Apply film to bumper and work out the bubbles. The solution on the bumper will allow you to maneuver the piece / slide / etc until you get it right.
    Step 10: Stop. It's good enough. Run away. Do not touch again - it will only get worse.
  13. peterjmc
    917
    188
    Clarksburg, MD
    F8L and Kit Shah like this.
  14. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Looks hard to shift
    burstaneurysm likes this.
  15. peterjmc
    917
    188
    Clarksburg, MD
    It's actually very easy to shift and comfortable. Imagine holding your phone in your hand and sliding it where it needs to go.
  16. watchingthetides
    watchingthetides Junior Member
    33
    46
    Roof spoiler came. My puppy is also excited
    Quick install. Florida weather made it almost unbearable though
  17. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
  18. peterjmc
    917
    188
    Clarksburg, MD
    In addition to finishing my DIY phone mount.
    1) I finally got my Forgestar F14s mounted.
    2) I had the dealer disable driver and passenger seat belt chimes.
    3) I had the dealer enable manual recirculation control on the HVAC system :D
    Stance Stats....
    Wheel: Forgestar F14s, Textured Gunmetal, 18x8.5, +48
    Tires: Conti DWS 215/40/18
    Suspension: Lowered on Eibachs
    Misc: 5mm spacers in the rear
  19. tankyuong
    1,555
    661
    Central MO
    did you pour the concrete yourself?
  20. peterjmc
    917
    188
    Clarksburg, MD
    Nope. Came with the house.
