battery load when not in use
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by syscon, May 19, 2013.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does anybody know how load is on Prius v 12v battery when power is OFF ?
  2. kithmo
    kithmo Couch Potato
    2,404
    2,775
    47
    South Yorkshire, UK
  3. syscon
    syscon Member
    329
    43
    Edm. Alberta
    This is good information.
    Once my 12V battery dies on me, I will remove the internal bracket and put in Optima yellow top battery 55amh.
  4. boppo
    boppo Active Member
    799
    139
    Owego, NY
    You can also get a excide battery that replaces the OEM.
  5. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
    If you leave your v (or any car) in a secure area (garage); do not power lock it. When you do over an extended period of time, the security monitor set up is a continuous discharge. A few weeks, no big deal. Several months will leave a dead battery.
    Prius_Angie likes this.
