Sokie Tech Hood Damper
Discussion in 'Gen 3 Prius Accessories and Modifications' started by markdjr, Mar 29, 2013.
  1. markdjr
    markdjr Junior Member
    Just wanted to confirm that those who installed this kit did not use the supplied washers and bolts. I checked a couple of pics on here and it looks like everyone used factory hardware, which I did too, but want to make sure that I didn't overlook something. Thanks.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ur good. I just used the factory bolts on the brackets
    Burna J likes this.
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    is the install fairly easy ?
    just received mine today :)
  4. ePrius
    ePrius Member
    162
    76
    The install is very easy. Took me less than 10 mins.
    Just beware, if you installed a STB, grind down the STB bracket with a metal file. Otherwise it hit the hood damper.
  5. ucsmfu
    1,498
    420
    canada
    does it need to be filed down with the Cusco strut tower bar too ? I noticed that you have the tanabe one ?
    thanks
  6. peterjmc
    917
    189
    Clarksburg, MD
    I feel as though this will most likely only be an issue for the Tanabe STB and not the Cusco. The Tanabe STB follows close to the edge of the fender.
  7. ucsmfu
    1,498
    420
    canada
    thanks I just wanted to confirm that before installing :)
    Burna J likes this.
  8. peterjmc
    917
    189
    Clarksburg, MD
    I can't confirm for certain since I don't have them... :)
    But from my mental comparison in the way the Cusco and Tanabe STBs fit in the engine bay, and the install pics of the damper in the thread below... I can only assume you would be without clearance issues between the Soooooookies and the Cusco.
    Sokie Tech Hood Dampers | PriusChat
    ucsmfu likes this.
  9. ucsmfu
    1,498
    420
    canada
    awesome, thanks !!!
    btw, for those interested in the dampers, I suggest you to msg the seller directly for better prices :)
  10. Burna J
    1,070
    3,339
    53
    Long Beach, CA.
    Can you use them with your carbon fiber hood?
  11. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    they don't recommend it...... but I'm using it on my CF hood... just need to be gentle in opening and closing the hood.....
    Burna J likes this.
  12. ucsmfu
    1,498
    420
    canada
    haha, yeah, i'm scared to crack to chip it.
    BTW, Bino, how are you maintaining the carbon fiber hood ? wax ?
  13. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    same thing on how I take care of the paint.... wash.. wax....
  14. ucsmfu
    1,498
    420
    canada
    Do u know if our hood is uv protected ?
  15. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I believe there's a clear coat on it.... my hood hasn't faded yet... I have it for 3 yrs already and the car is parked under the sun the whole day......
    ucsmfu likes this.
  16. Seanzky
    Seanzky Member
    150
    28
    NY
    Just to let everyone know with '14 Prius that the installation requires a lot of trimming on the right side. I had to Dremel a bunch of plastic as the damper would sit on top of them causing the hood to not close flush on the right side. The right bracket also needed Dremel-ing so it doesn't push into one of the covers.
    I'll provide pictures or a video tomorrow if anyone is interested.
  17. Burna J
    1,070
    3,339
    53
    Long Beach, CA.
    I would like to see some pictures. :confused:
    Did your kit look like this?
    TopRamen and sfv41901 like this.
  18. Seanzky
    Seanzky Member
    150
    28
    NY
    Yup, same brand from eBay. Just looking at your pics, my 2014 looks like it has more plastic covers in that area. I'll go take pics and post them in a few.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I would like to see this too.....not aware of any changes on the '14 Prii
    VS980 4G ?
  20. Seanzky
    Seanzky Member
    150
    28
    NY
    Still uploading the video. My phone was running out of battery and the recording was acting weird.
    Are there other 2014 owners here who could share their experience, too?
