What gas station do you fill up at?
Discussion in 'Prius c Main Forum' started by GreenDustin, Apr 1, 2013.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    There's really nothing you can do if that's all that is available. If you are really concerned, the Feds are now saying E15 is safe for our cars, so you might want to join Maine in the protest against it.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Our car clearly states to not use more than E10... so I hope that isn't true.
    RocMills likes this.
  3. mmmodem
    2,732
    1,703
    Bay Area, CA
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    mmmodem likes this.
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    But then again... I believe the government will do just about anything to try and make a dime.
  6. R Scneider
    R Scneider Member
    86
    37
    2001 Acura TL that is suppose to only take premium. Go figure.
  7. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    I'm annoyed that Nevada does not require the ethanol rating, if any, to be listed on the gas pumps. And thus far I haven't found a single station attendant or manager who can tell me whether or not there is ethanol in their fuel. I generally only fuel up at Chevron or Shell.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ours are only required to put a sticker that says "May contain up to 10% Ethanol." They have them on the pumps even when the gas doesn't actually have any in it just to cover themselves.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    What makes sense to me is to fill up at a busy gas station. If it is used up constantly, there is no time for water to pool up in their gas. It is also another reason to use Regular in your Prius, it has sat there the least time.
    Shell V-Power® Premium Gasoline - United States
    May just mean they are all the same.
  10. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    either costco gas, military post gas, or any other cheap gas stations
  11. What about an enzyme or adding something when I go to fill up to "negate" the effect of E10? I bet whatever I add would also improve my fuel economy.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Energy density - Wikipedia, the free encyclopedia
    No idea how any of that would mix with gasoline, but I would not want to be first.
  13. mmmodem
    2,732
    1,703
    Bay Area, CA
    There's a lot of snake oil companies that would love to sell a product to you. Look I found one here.
    Star Tron Enzyme Fuel Treatment - Ethanol/E10
    In case you don't get my sarcasm. DON'T BUY THIS!
  14. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    Top Tier gas is better ...... Go to " Top Tier Gasoline ", for more info, and list of retailers.:)
  15. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    I use ARCO. In the town of Twentynine Palm CA. it is the lowest price gas, and I have never had a problem using it?
  16. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Here in Oregon there is no self serve gas, I believe that New Jersey is the only other state. I would rather pump my
    own gas but thats the law.
    All the tanker trucks that I see that service this part of Northwestern Oregon is by Harris Fuel, and I believe they stop at
    Fred Meyer and Costco, and probably other stations as well.
    I have used both Costco and Fred Meyer gas (regular w/ 10% Ethanol) and noticed no difference...
  17. Mendel Leisk
    41,400
    Chevron, Chevron, Chevron..., well unless it's just not available, out of town somewhere. I like their rep, and that they're the only ones left around here with free air.
    I'm also just familiar with their machines. Some other brands have started the nonsense where you have to pre-select an amount. The trick is to just pick the max (I believe), but just more hassle/confusion I can do without.
    Also, our municipality is full-service only, maybe the only hold-out in all of BC? I've bought gas here maybe once in the twenty plus years we've been here, despise full serve. Luckily nearby, more sensible communities are very nearby, on our commute. Anyway, wish Coquitlam would wake up...
    Also, what is up with Oahu? if you're out-of-state (or country) you cannot use your card at the pump, have to go in, leave card with attendant, tell them the pump you're on, and so on.
  18. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Shell has free air still, here in Georgia.
  19. firstrival
    firstrival Member
    102
    Shell or Chevron
  20. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Chevron. It is a California corporation and they pay Cali corporate taxes which helps in state residents. Pice is competitive
    Mobil and Shell are cheap near my home also
