Just saw this about our top speed.
Discussion in 'Gen 3 Prius Main Forum' started by attyjeff, May 23, 2013.
  1. attyjeff
    attyjeff Member
    153
    40
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That's in kilometers/hour.
    JeffD
  3. attyjeff
    attyjeff Member
    153
    40
    I know but it ends up being 120 I think in mph
  4. jdenenberg
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Nope, 0.62(Miles/kM)*150(kM/Hour) = 93 MPH. My 2004 Prius is software limited to about 104 MPH. :)
    JeffD
  5. attyjeff
    attyjeff Member
    153
    40
    toward the end he was at 194
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    194 km/hr would be around 121 MPH. Not sure how accurate the speedo is at those speeds.
    European Prius may not be speed limited, due to the Autobahn application. Top speed is power limited.
    There may also be some liability reasons the North American Prius is speed limited, while the European one might not be. Sue is a verb in the US. ;)
    jdcollins5 likes this.
  7. bisco
    52,404
    i have never been over 65 mph in any of my pri.:X3:
  8. Nikos
    Nikos Junior Member
    24
    Greece
    I did 178km/h going up-hill , a little while ago when some idiot in an Audi A3 needed some verbal abuse for driving like a total idiot (happens a lot in Greece...). Have done 185km/h on my previous 2007 Mk3 in the past going down-hill.
    Nikos
  9. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    just making sure I'm not seeing things, but is the instant MPG staying at 99 mpg?
  10. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    the car is running on willpower at that speed.
  11. CygnusX-1
    CygnusX-1 Junior Member
    This one came up right after the above link from youtube. Sweet mod on the car (except for the doors) but I'm going to go out on a limb and say they are not getting anywhere near 50 mpg on the car anymore.
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The metric "instant mpg" would be consumption, in l/100 km.
    Max scale is max consumption.
  13. David Beale
    5,963
    1,989
    Edmonton Alberta
    Yup, when the accelerator is pressed to the floor it reads "99 l/100 km". Glug glug!
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    At very high speeds the Prius becomes unstable due to the unique aerodynamics designed for fuel efficiency instead of downforce.
  15. Brock
    Brock Junior Member
    40
    I've had my Prius up in the high 90's (mph) on multiple occasions, got it up to around 93 going up the big mountain/hill north of Phoenix on Black Canyon HWY (that only works when there aren't any *&^*&^_$# to cut you off)One of these times we are going to try to max it out on the way to Vegas since there is an uber long straight road.
  16. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've maxed my 2010 and it was very stable on an outback sealed but bumpy road. Haven't done it since and won't do it again.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    It's fine as long as there are no crosswinds and you don't have to make quick steering changes. :)
  18. Feri
    Feri Active Member
    761
    144
    Yeah maybe! The road was dead straight.
