Private Hybrid Repair shop?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PRwanting, May 25, 2013.
  1. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    Does anybody know how I can find a private Hybrid repair shop in Boston area or in Massachusetts in general? I'm sick of overpaying for everything at the stealership. Any help will be appreciated.
    Thanks.
    52,366
    what kind of work do you need? most any certified mechanic can work on a prius.
  3. PRwanting
    48
    Boston, MA
    They can? The dealership said they can't since this is a hybrid car.
  4. bisco
    52,366
    almost any mechanic can do 90% of the car which is the same as any other car. many mechanics can do larger hubrid work like batteries and inverters and hybrid drive system. you won't likely need those services. oil changes, filters, belts, hoses, brakes, tires, exhaust, spark plugs, pcv, and many more can even be diy'ed.
    PRwanting likes this.
  5. PRwanting
    48
    Boston, MA
    Thank you. Appreciate your input.
