Proud New Owner in New Jersey!
Discussion in 'Newbie Forum' started by Graymalkin56, May 26, 2013.
  1. Graymalkin56
    Graymalkin56 Junior Member
    New Jersey
    I just bought a 2013 Prius III in dark gray. It came with the solar moonroof and Audio Display with navigation and Entune. It replaces my 1998 Camry, and I expect it will be the last car I ever buy.
    I may not be the ideal driver for this car. I usually do about 3,000 miles a YEAR, most of them very short hops for my commute. So I'm not expecting 50 mpg. But I still want to reduce my gasoline consumption as much as possible without buying an all-electric plug-in, as I have no place to put a charging station. I hope this is the solution.
    Looking forward to participating in this forum!
    cwerdna likes this.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Welcome! I'd imagine you recognize me from TiVocommunity. ;)
  3. pakhong111
    pakhong111 Junior Member
    31
    Good luck and all the best. Routine maintenance is all you need and your new Prius will last. I am the original owner of a 2004 Prius with 211,000 miles driving 130 miles roundtrip (entire length of Rt. 78 in NJ), for work daily. Highest mpg 55.1. The only issue that I have is the car burns 1 quart of oil every 1500 miles. Enjoy your new car!
  4. bisco
    51,561
    congrats and welcome! if you find your mpg's disappointing, take a look at the pip, perfect for those short trips and all the benefits of a regular prius. all the best!(y)
  5. Graymalkin56
    New Jersey
    If PIP means "Plug-In Prius," that isn't an option unless I move to a new condo or house. That would raise the overhead cost of a PIP by quite a bit ($30K for the PIP, $300K for the charging station). :p If my retirement goes as planned, my next car will be all-electric -- but it'll be an all-electric golf cart.
  6. bisco
    51,561
    here's hoping it goes as planned. hit 'em long and straight my friend.(y)
  7. Graymalkin56
    New Jersey
