Optimum EV Speed
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 25, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Can someone please confirm what the most efficient EV speed is? If I remember correct I think it is 15-18 mph but not sure. Anyone else remember?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Optimum for what?
  3. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    The electric is pretty linear. However anything using less than 11 HP is considered a sweet spot but the only way your going to see that gauge is by going to HV mode.
    iPad ? HD
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yea! thats about the best, if you are not holding up traffic! Good luck with that one! :)
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Most miles per kWh of battery charge. Sounds like a good number. I do a lot of 25mph and 30mph on city streets.
  6. bisco
    52,398
    where are you getting the 15-18 from? i don't recall seeing that anywhere.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have no idea, I just figure anything from about 15-25 if possible is going to be as good as it gets! :D
  8. markabele
    5,084
    1,782
    Nebraska
    Ken came onto one of the gen3 threads and said that. He had an exact number though. Should apply here as well.
  9. bisco
    52,398
    thank you, i must have missed that.(y)
  10. El Dobro
    El Dobro A Member
    7,093
    3,271
    I just drive what the street allows. No need to rev anyone up. :D
  11. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I concentrate more on timing signals and watching traffic in order to avoid having to accelerate from unneccessary stops. On city streets I keep to the right at around 35 mph, and usually get about 14-15 miles on a charge before any use of the ICE. I can see where driving at 15-18 mph would impede traffic and really make people angry.:(
  12. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Been wondering the same here. On the very slowest end, near 0 mph, rolling resistance would be an obstacle to high EV range on a single charge. However, the faster one goes, wind resistance becomes more of an issue. Intuitively, speed in the teen mph range sounds right. Anyone here have some real data/calculations? I agree with retired4999 - traffic makes this an untestable question for most of us.
  13. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    On our small back country roads where no traffic is, I have on many occasions used 24mph.
    This is the slowest speed Cruise Control can lock in at. I could have gone slower but have not gained much EV distance.
    I can get 17+ EV miles everytime at 24mph. And its nice using CC not having to modulate with your foot.
    Try to keep your HSI indicator bar at the very bottom, since the higher the indicator bar is the more battery you use.
    iplug likes this.
  14. markabele
    5,084
    1,782
    Nebraska
    Traveling right now so I can't look it up but ken had all the calculations on a similar thread on the gen3 forums.
    Found it!
    What is the optimum speed for under 25 mph in EV mode? | PriusChat
    iplug likes this.
  15. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Thanks! Looks like Ken came up with 14-15 mph for max EV efficiency (kWh/mile). Also, looking at his figures, one loses almost 19% going from 15 mph to 30 mph. Meanwhile, driving within 10-20 mph keeps one within 3% of maximum efficiency. Now if only our PIPs could drive on autopilot so we could read a good book as it would take an eternity to drive anywhere at this speed. And there is still the problem with the angry line of vehicles honking behind us.
  16. RBooker
    RBooker Member
    154
    56
    Does this help? The data is for a Tesla Roadster. However, I at load speeds I assume little difference in Wh consumed between different vehicles. The data suggests the best strategy is to accelerate quickly to 15 mph.
  17. CaliforniaBear
    1,180
    289
    Northern California
    This graph seems a little optimistic for the Prius perhaps by a factor of 2. It certainly gives a good idea of how miles/kWh varies with speed.
    Prius battery 4.4 kWh
    Usable SOC range 20% to 85%
    Usable kWh 0.65 * 4.4 = 2.89 kWh
    From the graph
    135 Wh/mi at 20mph >> 2.89*1000/135 = 21.4 miles at 20mph
    175 Wh/mi at 40mph >> 2.89*1000/175 = 16.5 miles at 40mph
    250 Wh/mi at 60mph >> 2.89*1000/250 = 11.6 miles at 60mph
    markabele likes this.
  18. kkitzhaber
    kkitzhaber Member
    Owen, WI
    My best is 17.3 miles on one charge, cruise set to 25 mph. W/o cruise, and coasting in neutral down the hills with an average speed of 19 mph, I made 19.3 miles on the same route. Scangauge shows what I would call parasitic discharge while coasting in Drive mode. There is 0.8 to 1.3 kW drain in glide, while in neutral, the discharge is 0.2 kW. So, by coasting in neutral, some energy is saved. Fortunately for me, I live in rural Amish Country, WI. Almost no traffic. Haven't been passed by a horse and buggy yet. Some say THEY are low emission, but I've driven through their 'emission' a few times, and it stinks.
    retired4999 and RBooker like this.
