Turning navigation off?
Discussion in 'Prius c Audio and Electronics' started by farnlc, Jun 17, 2012.
  1. farnlc
    farnlc New Member
    Ankeny
    For the life of me I can't figure out how to stop the NAV after I figured out where I am. Sometimes I just need directions on how to get back to the interstate and don't want to listen to the directions all the way home. Right now I am just turning the volume on the maps down, but that seems silly.
    Side note, I have both iPhone and Android and the iPhone works beautify with cover art and song titles for a lot of apps including iPod, iHeartRadio, Audible whereas Galaxy Nexus just shows unidentified whenever I am streaming anything. It's really annoying....any Andintroid users have any interface tips?
    Lastly, iHeart was listed in the brochure as coming this summer? Anyone heard any update on new entune content?
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    From the navigation manual:
    On the Map screen: Options -> Stop Guidance
    You'd think there would be a voice command for this, but all you can do is say "Show Map" then follow the above.
  3. qbee42
    3,080
    With the Gen II you can use the voice command "suspend guidance" and it works like a charm. Perhaps that will also work on the Gen III?
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I ran through all the voice command options on the C and "suspend guidance" isn't one of them. It's a surprising omission, especially if it was on Gen II.
  5. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    "Suspend guidance" is gone on the Gen II in 2012. It's the thing that irks me the most.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Is "DESTINATION", "DELETE DESTINATION", "YES" available?
  7. qbee42
    3,080
    2012 is a Gen III Prius.
  8. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Just checked, not there.
  9. jabecker
    448
    78
    Portland, Oregon
    That's what I meant. Switched from a 2005 to a 2012, and sometimes I forget. Or I just need more coffee.
  10. Joss
    Joss Junior Member
    Melbourne, Australia
    Top right hand corner of the map screen you'll see a button with some squares and an arrow.
    When this is clicked a menu will appear on top of the map.
    You need to select Cancel Navigation and then confirm to cancel it or keep it.
    This will go back to just showing the map and now telling you where to go.
  11. Optical Illusions
    Optical Illusions Junior Member
    42
    You can get iHeart, Pandora, OpenTable, MovieTickets, Sports, Stocks,Traffic, Fuel Guide etc.. If you update your Entune to version 2.1.0. You can call Toyota and they will send you a USB for that update... Now for the 2.2.0 update, all i have to say is good luck with that since you have to go through toyota dealer and they will try to charge you even though it is free to update the Entune firmware.
  12. gbouten
    gbouten Junior Member
    48
    Alamogordo NM
    Do you have to be linked to your phone to use the Nav?
  13. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    No, navigation is completely independent of the phone. Traffic info needs a connection, of course.
  14. gbouten
    48
    Alamogordo NM
    Thanks I didn't think so
  15. gbouten
    48
    Alamogordo NM
    I have I heart on mine after they did the last service update. Free of charge
  16. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    It appears from reading posts here and over in the Club Lexus forums that sometime in the last couple of years or so the Toyota/Lexus software engineers have made some poor choices regarding the NAV firmware.
    2013 Lexii NAV = Bad, Bad, Bad!!! | PriusChat
    The 800# for Lexus Customer Service is 1-800-255-3987
    The 800# for Toyota Customer Service is 1-800-331-4331
    Hopefully with enough targeted complaints the "Suspend Guidance", "Resume Guidance" and muting of guidance during phone calls will return in the next firmware release.
    Ohhh for those of you getting lost while making a phone call please try leaving your map screen up and follow the turns displayed on it. Or if you have a HUD follow the turns there. These should still be available while on the phone. If not add it to the list of fixes for the next firmware release. Kind of sad that our almost decade old NAV's in Ema and Myrtle are more user friendly than the 2013 revision.
    Happy driving,
    Chris
