What's the best EV mod?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jdjeep98, Jan 25, 2006.
  1. None - I can always run in "stealth" mode if I want.
    0 vote(s)
    0.0%
  2. None - I'm scared to death to touch anything.
    0 vote(s)
    0.0%
  3. Two wires - It's cheap and I can always rip them out.
    0 vote(s)
    0.0%
  4. Generic Push Button - Cheap, easy, and I can put it in the blank.
    0 vote(s)
    0.0%
  5. Headlight Flash Mod - Cheap and invisible - I never flash my lights.
    0 vote(s)
    0.0%
  6. Cruise Control Cancel - Minimal dash disassembly - I like that.
    0 vote(s)
    0.0%
  7. OEM Button - I like the stock look and don't mind the dissassembly.
    0 vote(s)
    0.0%
  8. Two Key Switches - One, two, three, NOW!
    100.0%
  9. Secure Keypad - I don't want anyone to be able to do it but me!
    0 vote(s)
    0.0%
  1. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    What do you think?
    Did I leave anything out?
    I'm really interested in your opinions. Maybe it'll help me make up my mind for my own mod... :blink:
  2. aaf709
    3,862
    2022 Prius Prime
    Too bad you can't have Voice, as in pressing the button on the steering wheel and saying, "EV MODE ON" after which you'll get the reply, "Displaying Banks." :)
  3. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    Ooh! Ooh! I like it! Can I add that to the poll???
    B) :D :lol:
  4. Tideland Prius
    16,539
    I'd like an OEM button but yeah, the assembly is what steered me towards the CC method.
  5. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    My OEM button is being installed in
    T - 3 days
  6. darelldd
    6,059
    389
    Northern CA
    Yay. I'm winning!
    Still, the "best" EV mod would be the plug-in variety!
  7. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    Awesome! B) (I haven't got a ship date from Sigma yet.)
    I'm expecting my Coastal package on Friday.
    Yes, I bought both. I figured that after I decide which one to use, and I'm leaning toward the OEM button right now, I can probably sell the other one either here or on eBay.
  8. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    I SOOOOOO want to be able to plug in my Prius! B)
    (I was seriously looking into doing an electric conversion before I decided on the Prius.)
  9. judibob
    judibob New Member
    Copper Country
    I've gone with the OEM button, and while the install was patience intensive, it ended up very clean in the end.
    FWIW....
  10. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I selected OEM but have both installed. Since they were installed by a Toyota Tech, installation was no problem.
    I don't see where a plugin version would be of much benefit without additional battery capacity.
  11. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    You have both the Coastal and the OEM? Which one do you tend to use? The only problems I've had with the Coastal is finding it when the wheel is turned and sometimes I'm not sure if I've held it long enough, especially when starting up for a short move.
    Indeed the extra battery capacity would be great, but, after I come home through the neighborhood and my battery is showing 2 or 3 bars, I'd like to be able to plug it in and get it back up to 80% again. Otherwise I just have to spend fuel to do it later.
    (It would be nice if a battery minder for the traction battery could be combined with a block heater...)
  12. KMO
    KMO Senior Member
    1,936
    669
    Finland
    2023 Prius Prime
    You're missing a "My Prius came with the button" option; without this people from outside the US might be unhelpfully skewing the poll towards "OEM".
  13. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    My sincerest appologies for neglecting to include our friends overseas! :eek: (You know how we yanks are... ;) ) If I knew how to edit a poll (I don't think you can), I would certainly add a button for you: "We've already GOT one, you know..." :p
  14. seasalsa
    1,278
    Kent, WA
    I tend to use the OEM most for the reason you mentiioned.
    Unless you have a block heater the ICE will have to run through the complete warmup cycle which will bring the charge back up so there is probably no gain.
  15. KTPhil
    KTPhil Active Member
    1,379
    I prefer the OEM. But I installed Coastal's.
    I don't want to even enter an argument about warrantee coverage, so I don't want any dealer to know I use EV mode. Once the warrantee is over (150K miles in Cali), I'll install the OEM button I bought. Untiil then, it's stealth EV with Coastal.
  16. OverTork
    OverTork Junior Member
    68
    Northville, MI
    I'm really surprised more people don't choose the headlight flasher mod.
    1. No parts to buy except the one wire.
    2. No wires for switch lighting.
    3. No altering of cruise control functionality.
    4. Completely invisible and reversable.
    5. No more disassembly than any other EV mods.
    Although the headlights won't flash with headlights off they will flash when the low beams are on. I understand flashing may shorten the life of HID headlights and should be avoided anyway.
  17. kdmorse
    kdmorse Member
    205
    Germantown, MD
    Headlight flasher - love it :)
    Will probably undo it when my real OEM button arrives, or perhaps I will spice the two together. The headlight flasher may be easier to hit that the little OEM button, which is in a nook I rare put my hands.
    All Hail whoever first thought to use the purple wire!
    -Ken
  18. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    FYI, the Coastal mod qualifies for 2-5. (There is no altering of the cruise control functionality with it installed.)
  19. darelldd
    6,059
    389
    Northern CA
    Indeed, a plug-in version would include more battery capacity and less engine capacity.
  20. darelldd
    6,059
    389
    Northern CA
    I still have the luxury of time to decide which way I want to go with this... and you've brought up a couple of questions:
    1. "Flashing" the lights usually means blipping the high beams
    2. If the low beams are on, the typically stay on when the high-beams are flashed (true in the Prius?)
    3. Only the low beams are typically HID because of the "warm-up" period. (true of the Prius?)
    So what I'm saying here is that with the lights off, "flashing" them powers the high beams, so it wouldn't matter as far as the HID business is concerned, no?
    My main concern with going this way is when the headlights ARE on, at night, and I'm behind somebody and want to enter EV mode. I'm not all that keep on having to flash the guy in front of me, or the on-coming cars.
