Is it possible to "order" the OEM 15" alloy rims?
Discussion in 'Prius c Main Forum' started by hexcode, May 26, 2013.
  1. hexcode
    hexcode New Member
    I am shopping for a 2013 Prius c Two and wanted to know if it was possible to "order" the OEM 15" alloy rims from Toyota or aftermarket shop (the ones available on the Three/Four trims)? Toyota lists them as a $400 option, is it something the dealer could do?
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    The dealer should be able to order it for you. The c in Australia comes with cool wheels that I want to order.
  3. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Aren't the alloy wheels 16"?
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Only on the Four, which has a different steering rack if you get the 16s.
    15" alloys are an option on all trim levels.
  5. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Had no idea. Do they look like the 16" only offered on the c4?
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I got them as an option for my Three, and they look like this:
  7. hexcode
    hexcode New Member
    Technically, I think they are only an option on the Three and Four trim levels.
    Which is why I was asking if the dealer/aftermarket could order them for a Two trim level.
  8. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Okay, I see. They also look like the 16 inch rims that are offered on the C 4. Didn't know they had the 15 inch version.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    They, in fact, are only options on the 3/4.
  10. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I misremembered this! I was originally considering the Two when I bought my c last year, decided on the Three instead to get the smart key and other features, then added the alloy wheels and moonroof.
    You may well find that a dealer wants full retail for alloys on the Two, which will be considerably more than the $390 option price. Worth checking around, or consider aftermarket alloys.
  11. mahout
    mahout Active Member
    655
    116
    NC
    For gosh sakes don't order the Toyota wheels unless you love handling out money. The aftermarket has a wealth of wheels and tires at lower prices. . Start with tirerack.com to get details on the tires and wheels. Check discounttire and other internet sources, too.
    You want 15" wheels at 6" or 7" rim width, 4x100 BC, 40 to 45 mm offset. Tires 195/55x15 is a good choice in whatever kind you want : winter, all-season, summer, treadwear, performance, inexpensive, style, whatecver floats your boat. Yeah, don't get truck wheels and tires either.
  12. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    The OEM rims are 5" width. If you want to use the stock tires and stay with stock wheel dimensions as much as possible, the aftermarket doesn't offer anything close to the stock width.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    There are tons of 15x5.5 wheels on the aftermarket... the OEM tires will fit that with no problem.
    mtbiker53 likes this.
  14. Mendel Leisk
    40,964
    I entertained getting extra OEM wheels when I was shopping for snow tires. They have them, but the price...
  15. Merkey
    Merkey Active Member
    308
    279
    Birmingham, Michigan
    Try parts.camelbacktoyota.com. They list OEM 15" alloys for the 2012 Prius C for $255.74 each. That's about $100 less than list. Still lots more than if they came on car. I bought OEM trim rings for my 2006 from them at considerably less than my dealer charged and shipping was included.
  16. mahout
    655
    116
    NC
    Thank goodness the aftermarket wheels are 6 or 7" width and the 15x6 is a great choice for your 15" tires too. Judst stick with 40 to 45 mm offset and the ones you like the look. The reason OEM is 15x5 is the 175/65x15 tire; check the recommended rim width for the 195 width tires at tirerack.com
  17. daboy
    daboy Junior Member
    51
    got my oem alloy from another member here.
  18. wmo168
    wmo168 Member
    239
    South Florida
    Luckly u, I am still looking for people who selling their 15"
