  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Good luck with the install. Hit me up if u need any help
    ucsmfu likes this.
  2. ProphetsOfDoom
    95
    93
    64
    Virginia
    Wrapped the hood with 3M 1080 this weekend. Also upholstered the door panels in Clazzio leather :cool: 20130527_172907.jpg 20130527_172955.jpg
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    are you going to write a DIY for the door panels :p It looks awesome !!!!!
    Dawit likes this.
  4. peterjmc
    917
    189
    Clarksburg, MD
    I put all the stock wheels back on. The Forgestars and tires have some balance issues that need to be fixed. Not sure if its the wheels, tires, or a bad balance
    Also, I'm ordering some 225s to replace the 215s, I don't like how the lip of the wheel is so exposed.
    I hope that this shop can fix the balance issues and I can mount all four of these wheels back on the 11th.
  5. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
  6. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    sfv41901 and FishCandy like this.
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I like the door handle covers and I'm considering them as well. I also think the rear hatch door is missing something, maybe a thin trim piece along the bottom.
  8. ucsmfu
    1,498
    420
    canada
    got the JDM folding mirrors installed today, thanks Sean for your help with the wiring :)
  9. ProphetsOfDoom
    95
    93
    64
    Virginia
    Thanks man! I didn't take pictures of the process (my bad!) but i'll be more than happy to answer any questions anyone has. Maybe I can write something up this weekend.
    fyi I got the Clazzio leather from HAWAIIANBUILT here on PC (thanks bro! :D).
  10. ProphetsOfDoom
    95
    93
    64
    Virginia
    On my wish list... but i think i'm going to go with the REMIN dash kit first.
    Look'n good bro!
  11. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Looks great~! I'm jealous, because yours is 2010 which is Plug&Play and mine is not.
    Did you get the 3-in-1 led too? And did you also swap out the folding motor into the US mirrors?
    And how long did it took you to get this done?
  12. peterjmc
    917
    189
    Clarksburg, MD
    Does your new mirror switch illuminate?
  13. ucsmfu
    1,498
    420
    canada
    haven't tested them in the dark yet, do the jdm switch illuminate in the dark ?
  14. ucsmfu
    1,498
    420
    canada
    yes, I had to swap out the folding mirror out, except to the Canadian mirrors, there were some adjustments that needed to be made, took my installer roughly around 8 hours ><
  15. peterjmc
    917
    189
    Clarksburg, MD
    I thought I remember seeing a thread where someone had an illuminated switch. Just wondering if yours did or not. Looks good though UCSMFU!
  16. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Agree on the hatch door observations...
  17. gobcycle
    gobcycle Junior Member
    Central PA
    Installed Proxel electomagnetic rear parking sensor. Uses metal tape mounted inside of bumper.
  18. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    nothing special.....
    had the 40K service done.... and the dealer broke the engine splash guard where the oil filter access is.... (the panel came loose when I was at the freeway and before I could stop the part that came loose broke off and I was not able to save it... :mad: )
  19. Bingee
    Bingee Member
    210
    62
    Michigan
    I finally registered/joined this group
    Bullet Salvador, sfv41901 and Burna J like this.
  20. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    do the mirrors fold in for highway hypermiling?
