Possible 2nd Hybrid System Failure
Discussion in 'Gen 2 Prius Technical Discussion' started by misfit8877, May 20, 2013.
  1. misfit8877
    misfit8877 New Member
    Hello,
    I wanted to know if anyone else has run into a problem like mine.
    Here are my car specs: 2006 Toyota Prius, bought new in Oct 2006, currently at 90,000 miles.
    It just recently broke down on me about a month ago, the dashboard lit up like a Christmas tree with every possible light flashing and nav screen showing "problem."
    I took it to the Toyota dealership and they determined it was a hybrid system fail and replaced the battery.
    After this, I'm thinking all is well.
    I go out of town this past weekend 130 miles away from where I live and day 2 into vacation my dashboard lights up again! Same lights, flashing red triangle, Vsc, check engine, etc. it gets me back to my hotel but the next morning the engine won't start. At least the first time it broke down the cars engine worked and was somewhat drivable!
    Could this be the battery and hybrid system again? What do I do? Should I sell it? Shouldn't it be able to survive long trips?
    There's so many worries I now have because of this situation, any input would be greatly appreciated!!!
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    90K mile hybrid failure, I don't believe it. You have a problem somewhere, and your dealership misdiagnosed it the first time. Good news is that you got a new battery for free, so yippee.
    It sounds like an inverter coolant problem if I had to guess with limited info. After driving a while, it got hot, and shut down. In this situation you won't be able to go anywhere. Easy to check. Have you had the inverter coolant pump replaced under the recall? Open up the top of the fluid reservoir and see if there is any turbulence with the car in READY.
    Another possible issue that's fairly common and causes incorrect traction battery diagnosis would include the 12v battery being nearly dead. It can be way past dead when compared to a normal car, but still start the Prius. Then when driving the load will be quite high. Your mpg will suffer a bit, the 12v will get hot, and your inverter will work overtime.
    nh7o likes this.
  3. misfit8877
    Thanks for taking a look at my post!
    I did get the coolant pump replaced after the recall at my local Toyota dealership. Honestly, anything that pops up as a recall I take my car to the Toyota dealership ASAP to get the problem assessed.
    I'm just confused as to why this is happening, everything is up to date (maintenance, etc) and I even had the oil changed about a month ago!
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    We have seen a number of cases where the dealership did not diagnose the car properly. If possible please list the DTC's that were read. I agree with the above, that the 12V is suspect until proven otherwise. Also, perhaps there is still air in the coolant system. That too has happened before.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Keep in mind that the inverter coolant loop is a very critical part of the hybrid drive. Did the first "failure" occur before or after you had the recall work performed for the coolant pump? Dealer techs are people and make mistakes. Unfortunately making a mistake in this very complicated system means catastrophic failure. The good news is that the Prius lights up to tell you it is in pain, and then shuts off the effected systems so you don't run it into the ground. It is not uncommon for techs to not bleed the system properly and there is air in the loop. Or not to tighten one of the parts all the way and over time the coolant leaks out, etc, etc, etc.
    If you can check the turbulence in the reservoir really quickly, now would be a good time. Takes 30 seconds. :)
  6. misfit8877
    Once I find my documents from the dealership with last months repairs I will definitely provide the DTC's!
    Currently my car is at my local dealership but can't be worked on until tomorrow, so once they give me the new info I will also pass that along!
  7. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Could be multiple failures of different items all close together
  8. misfit8877
    This problem happened after my recall work was done. The coolant pump was replaced last year, the first hybrid system failure occurred last month!
    All very troublesome and is currently making me feel like I'm driving an unsafe car. :(
  9. JMD
    3,779
    1,282
    See what the Mechanic says.
  10. misfit8877
    Update:
    It is definitely another hybrid system failure, the technician is obtaining codes as we speak. But from what the technician is saying, its only showing a general hybrid failure, very vague. Apparently the car isn't showing any other codes when it SHOULD be showing something more than just a general problem. They are trying to figure out where the system failure is coming from.
  11. Gavin Craske
    Gavin Craske Junior Member
    Perth, Western Australia
    I've had two inverter pumps fail one after the other and through no fault of the Hybrid system. As mentioned above double check the turbulence again and failing that not more can me done until the codes are retrieved as there are too many variables to deal with.
    Good luck,
    Gavin.
    Current Tech Auto Electrical.
  12. Bruce Fealk
    Bruce Fealk Junior Member
    I'm having a similar problem. The first time it occurred, the red triangle came up and the tire pressure warning light. I turned off the car and tried to restart, several more warning lights and now the car won't start. The dealre replaced the auxillary battery and sent me on my way.
    I was driving on the free way, same thing. The red triangle and the tire pressure warning light come on I drive to my destination and turn the car off and try to restart, car won't start.
    I get towed to the dealer and they diagnose the inverter. I get the inverter replaced, drive home, stop for dinner, pull out of the restaurant, drive a 1/4 mile, the red triangle comes on again with the tire pressure warning light. I get home, try to start the car, all the same warning lights come on and the car will not start again.
    Ideas?
  13. nh7o
    1,686
    340
    Hawaii
    That sounds like a very different problem. I suspect the 12V battery is not being charged, which is what the dealer suspected when they replaced the inverter. Since it is still the same, they just guessed the problem without really looking into the situation. It is necessary to get codes read and listed here, although if the battery is going completely flat, they may be getting erased. A voltmeter reading of the 12V battery is a place to start. Put a charger on it and make sure it is completely full, and then test to make sure it is being charged by the inverter when the car is in Ready mode.
    Please list the numbers from this test:
    Entering Maintenance Mode (aka 12V Battery Check) without Switching Headlights ON/OFF | PriusChat
  14. Bruce Fealk
  15. Patrick Wong
    18,210
    6,514
    DTC P0AA6, info code 526 means that your car has a high voltage leak, but it does not necessarily mean the inverter is the problem. Any component in contact with high voltage could be the problem: traction battery, traction battery ECU, high voltage cabling, inverter, or transaxle.
    Typically, another three-digit info code (ranging from 611 to 614) will appear which will help to narrow down the issue. I assume that your car is under hybrid system warranty?
    This problem has nothing to do with your tire pressure warning light or that system.
    How about posting sharp photos of the warning lights and icons that appear?
  16. nh7o
    1,686
    340
    Hawaii
    The A/C compressor is also in that list of HV leakage possibilities. Has the A/C ever been serviced?
  17. Bruce Fealk
    Here are pictures of the warning indicators. IMG_20130601_052449.jpg IMG_20130601_052429.jpg
  18. Patrick Wong
    18,210
    6,514
    The first photo shows the hybrid vehicle warning icon. That tells you there is something wrong with the hybrid system.
    The second photo shows the master warning red triangle, which just tells you that something is wrong. I believe the first amber light is the traction slip warning light. The second amber light is the brake system warning light. The ABS and check engine lights also are on. So this shows you that the skid control and engine ECUs have logged DTC as well.
    Therefore, there should be DTC besides P0AA6.
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    When the inverter coolant pump fails and the inverter begins overheating, one of the first system to shut down is the DC to DC converter which provides the charging to the auxiliary battery. One consequence of this is that sometimes the DTC's get lost and the problem misdiagnosed. This might be the case here.
    See above.
