Question on Rear Bumper Protector installation
Discussion in 'Prius c Accessories and Modifications' started by Basco, Jun 1, 2013.
  1. Basco
    Basco Junior Member
    Sacramento, CA
    I just received the rear bumper protector (PT738-52120) for my new Prius C and was looking at the instructions and it says to to use 3M prep solvent 70 to prep the bumper. I cannot find this stuff anywhere locally. Is this necessary to do or can I just clean off the bumper with a lint free cloth and apply? If it is recommended to use the solvent is there another product that is the same that I can buy at the store?
    Thanks
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    that particular step isn't needed... it's a prep to make sure the bumper is absolutely clean and free from anything that can possibly affect the adhesive.
    wash the area thoroughly and you'll be fine.. microfiber, lint-free.. make sure there's no wax or anything.. etc..
  3. estebinbin
    estebinbin Member
    184
    47
    I also ran into this problem. In many forums they recommend cleaning the area with ribbing alcohol...
  4. X HCH2
    X HCH2 Member
    119
    Upstate SC
    All you're trying to do is remove wax, Armor All, etc so that the piece will stick.
    I usually just use alcohol.
    X
    xpcman likes this.
  5. Basco
    Basco Junior Member
    Sacramento, CA
    The car is a week old and have not even washed it yet, so no waxes or polish on the car yet.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Alcohol wipes...
  7. Basco
    Basco Junior Member
    Sacramento, CA
    Thanks everyone. I was able to use a little Stoners Invisible Glass since it has alcohol and cleaned it up before applying the protector. Everything went very smooth.
    ztanos likes this.
  8. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Post some pictures.
  9. Basco
    Basco Junior Member
    Sacramento, CA
    Here are some pics of the bumper/net/and cargo tray
    TheyCmeNow likes this.
  10. Mendel Leisk
    41,898
    I'd second rubbing alchohol. Get the 99% stuff; I think the 70% formulation might have a bit of oil. You really just want something that will take off grease/dirt. And definitely not take off paint.
    Oh, see it's a done deal, never mind...
  11. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Looks good man.
  12. ttran97
    ttran97 Junior Member
    I think it looks really good with the cargo liner!
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I think it's crooked. :)
  14. iSphinx
    iSphinx Junior Member
    31
    I did mine the week I got my car and it was very easy and simple! The dealership wanted to charge me $50 to install a peel-n-stick bumper guard -.- all I did was just wipe it down real good and used a dry erase marker to make tiny dots of how it was going to be aligned and it turned out great! It was actually my first DIY project on this car :)
    ztanos likes this.
  15. Jazzpiano
    Jazzpiano Junior Member
    Does anyone know if it has to be a certain temperature to apply this? I am affraid its too cold right now in NY.. 25 degrees F.
  16. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    I would wait till it is warmer to make sure the tape will stick properly to the surface.
