Transmission fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by attyjeff, May 23, 2013.
  1. attyjeff
    attyjeff Member
    153
    40
    I was wondering about this myself and there are a few threads on here, its very easy to do on your own, I called around and every dealer I called said I didnt need it until over 100,000 miles, well there is only 4 qts in the transmission thats a long haul for that oil. then when I pressed them they wanted $280. to do it. Anyway, I have attached a video I found, its just as easy with ramps and a funnel with a long hose. Some have said that they will change the oil at 5,000 to get the break in stuff out, I'm thinking 30,000 is a safe but thats just me, here is the video if you are interested:
  2. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Very good idea to change this fluid.
    Question is, is this video applicable to Prius 2010 3-rd gen.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,739
    Bay Area
    It looks like the Prius is a 2nd Gen.
  4. Former Member 68813
    3,524
    983
    US
    Location of those plugs in 2nd gen is different from what I saw in my 3rd gen.
  5. attyjeff
    attyjeff Member
    153
    40
    I will crawl under and look. I thought it was the same based on the videos I saw not just this one.
  6. attyjeff
    attyjeff Member
    153
    40
  7. syscon
    syscon Member
    329
    43
    Edm. Alberta
    How to level the car for transmission oil change?
    I know the car has to be level in order to fill IN the correct amount of fluid and my garage has a bit of grade level but I'm not sure if it has any significance.
    When I lift the car by front center point with my 2ton jack, I was only able to raise the car by 6.5in.
    When I use my ramp the car will be up by about 8in.
    Enclosed it the picture of the underneath are these save jacking points the circle and the X
    If I put a jack under the circle the crew will be damage I think; the "X" point with wooden block might be better choice
  8. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I don't think these screws (drain and fill) are visible from underneath unless you remove the plastic cover.
    Here is a good picture posted by "rrg"
    DIY Transmission Fluid Change? | Page 11 | PriusChat
    From his profile has has 2011 model so I think this would be applicable to our "V" as well.
    If these screws are sideways the leveling is not mush of an issue.
  9. NutzAboutBolts
    1,693
    1,739
    Bay Area
    here's a picture showing you where to jack your vehicle up and putting the jack stands.
  10. NutzAboutBolts
    1,693
    1,739
    Bay Area
    That's probably the 2nd generation Prius, the 3rd generation Prius, you'll have to remove the whole plastic panel for a clean drain and refill, I'll do this video when I hit 30k or so. :)
  11. Mendel Leisk
    41,401
    The X-mark is where I put my front safety stands. I put the rear safety stands per the diagram nutzaboutbolts posted above.
    My main issue was with the extra weight in the front, the shallow arch of my safety stand's cradle and the near knife-edge rocker panel edge bearing on it. Seemed skittish the few times I used those points. I think it's Hobbit posted pics of similar support location on gen 2. It works for me.
    If your garage is sloping a bit you can adjust the front or rear safety stand heights a bit to fix, or put plywood shims under the jackstands for finer adjustment.
    Do work safe. I like to push a chunk of tree stump under before getting under myself, thicker than me, makes me feel good ;)
  12. attyjeff
    attyjeff Member
    153
    40
    I did it yesterday it took about 45 mins and was very very easy to do. I only opened up the oil change flap. The fluid that came out looked like dr pepper and the new fluid was cherry red in color. I have 26,000 miles.
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't have a tree stump that big! :rolleyes:
  14. NutzAboutBolts
    1,693
    1,739
    Bay Area
    You can also take off your wheel's and put it on the side of the vehicle where the pinch weld is at. That will work to prevent any accidents from happening.
    retired4999 likes this.
  15. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Did you level the car? If so how?
    Did you pour IN the fluid from the top via 1/2 OD hose?
  16. attyjeff
    attyjeff Member
    153
    40
    Yes I put a small level in tbe door frame area. I used ramps and a floor jack to level the rear. Yes I bought clear hose from lowes in the plumbing area. It was about dollars.
  17. attyjeff
    attyjeff Member
    153
    40
    Believe it or not the hardest part was breaking the plugs loose. I had to use a breaker bar. They were really tight.
