70-mile-an-hour Warning
Discussion in 'Gen 2 Prius Main Forum' started by Mark Hollis, Jun 2, 2013.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok, cool that you just ignored everyone's advice. If you happen to get a "random" inverter failure in a year or two, you'll know that it wasn't really random.
    xs650 and kenoarto like this.
  2. Mark Hollis
    Mark Hollis Junior Member
    2023 Prius Prime
    XSE
    My mechanic checked the sensor and tole me the reading is -51 (fifty-one degrees below zero—not sure of the scale used here). He opined this may be a sensor problem.
    He also confirms that there is no turbulence in the reservoir when the car is in Ready mode.
    I shall update this as I find out more. My mechanic says that the pump is this really little thing over by the right-hand side headlamp.
