HOW TO DIY: JDM Folding Mirrors with Signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sfv41901, Jul 1, 2012.
  1. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    72
    98
    Brunswick, GA
    I was talking about the dash switch. I thot the comment meant that the switch would not work for US left-hand drive cars.
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    haha, sorry, I was talking bout the g's dash kit :p
  3. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    ok. I had panicked when I read it originally! lol
  4. ucsmfu
    1,498
    420
    canada
    did u buy it ?
  5. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    I had told my guy to buy it, then I shot him an email minutes later (after reading the post on here) and told him to see if it will even fit a US Prius before we proceed.... I was just getting ready to call him and tell him to go ahead now. I'd much rather have a lit one, cause it's already hard enuf to see things (to me) inside the Prius at night.
  6. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    The JDM switch part number is 84870-28040:
    If you don't mind sacrificing your 2012 switch, you can do what I did and mod it so it illuminates:
    You basically swap out the control pad from the 2012+ mirror switch, since the "MIRROR" is translucent and allows light to pass through and add two SMD LED chips onto the JDM switch:
    Trim down the rectangular plastic wall so it makes contact with the six contact points on the JDM mirror switch.
    I wouldn't recommend doing this because you effectively lose your OEM 2012+ illuminated switch. You have one shot at trimming down the rectangular plastic wall on the control pad - i.e. you mess up, you render your 2012+ switch useless. Oh and removing the control pad from the 2012+ switch is a big challenge with risk of breaking clips being very high.
    If you don't mind the implied risks involved, then it is possible for 2012+ Prius owners to convert their JDM non illuminated switch into an illuminated switch without buying a new switch.
    There's another Toyota switch that illuminates everything; i.e. the power folding button, "MIRROR" and L & R. I think it's found on the JDM Vellfire MPV and on certain Lexus models with folding mirrors. I bought said switch, used, from eBay for $75.00 listed as a Lexus switch but has the 16-pin 2012+ Prius connector behind it.
  7. peterjmc
    917
    188
    Clarksburg, MD
    Good post!
    So the Lexus switch you purchased did not work with your 2012 or it did?
    Thanks!
  8. Steve Type-4
    174
    102
    SoCal
    It fits, but not without a good amount of wire work which probably isn't worth it for most folks here.
    1.) Had to reverse wire the folding module (since it was designed for non-illuminated switches) to work
    2.) Had to mod the plug. The Lexus switch has 27 pins; the 2012+ Prius has 11 pins, the non-illuminated switch has 9 pins
    It's missing the "MIRROR" lettering which can be swapped from the 2012+ switch, but since I've modded my OEM switch, as you can see, it's no longer swappable.
    I'll probably JB weld it back to original state using sheets of plastic from Michael's and swap it into this Lexus switch at a later time when I have time. I'll probably write up a DIY guide for those that are truly interested, but as it is - probably not worth the time and cost for most folks here to go through all the trouble just to get a fully illuminated mirror switch.
    FYI - It lights up in the same green found on the 2012+ Prius switch.
    Bohemian Grove, mrbigh and ucsmfu like this.
  9. peterjmc
    917
    188
    Clarksburg, MD
    did anyone happen to try out the illuminated switch from Rakuten? :)
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Not yet unless ur willing to buy the switch for me to test :D
  11. larryt1026
    larryt1026 Junior Member
    61
    i want folding mirrors so bad...bu this mod appears to be out of my skill level
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Where are u located?
  13. larryt1026
    61
    florida lol
  14. 510bg
    510bg Member
    142
    SFV do you ever make trips out to NorCal? (Wishful thinking n my part)
  15. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    I live in Florida and have done a bunch of mods.. If I ever do the folding mirrors on my car and can probably see about doing it on your car also.. I'm in south Florida east coast.. Where are you?
  16. larryt1026
    61
    Oh wow, thanks for the thoughtfulness and I would totally take up your offer but I live all the way in Jacksonville. I'm from Boca originally though, so I know where you're at. Let me know when you plan on doing the mod, maybe if all my stars align I can drive down there. Where and what parts are you planning on getting it from?
  17. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
  18. ucsmfu
    1,498
    420
    canada
    folding mirrors still up for grabs
  19. mrbigh
    3,686
    699
    Long Island, NY
    what do you have available, color, fitment?
  20. ucsmfu
    1,498
    420
    canada
    2.) JDM folding mirrors, they are like new,- $700 Shipped
    comes with all the wiring leds and jdm mirrors still brand new, I might even have the kits you need for 2012-2013 install
    turn signals, all wiring included, blizzard pearl covers
    JDM blue tinted heated mirrors (+ free blue tinted convex mirrors )- free included with the folding mirrors
