Reasons NOT to buy the Prius C?
Discussion in 'Prius c Main Forum' started by Nel, May 20, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Nah, dude, the whole column literally points to the left. (wheels turned, would have stated steering wheel 'turned')
    Slide seat all way back, look down at face of steering wheel vs. front edge of seat, bingo.
    Tall guy sets c seat back and down and sandpaper textured steering wheel appears as though it belongs in another car due to its position, I say 'foul'.
  2. Nel
    Nel Member
    174
    84
    SF Bay Area
    Not sure what you're talking about regarding the steering column. Mine looks fine. Anybody else? Perhaps your spine is out of alignment :eek:
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Mine is straight...
  4. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Maybe your seat is coming off the track? Most cars require you to pull it all the way back to remove them, could be it went to far on one side.
  5. chengisk
    chengisk Junior Member
    ND
    The spine? :)
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Both my spine and the seat/wheel alignment ;)
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Easily seen. And yes, the 12 in ruler is flat against face of wheel.
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    That doesn't really help as your ruler isn't aligned with the seams on the seat. So it's going to look misleading, even if it wasn't off. I'm not saying your car isn't off, but you are creating an optical illusion by doing it the way you just did.
  9. Nel
    Nel Member
    174
    84
    SF Bay Area
    If it really is that bad, you could bring it back under warranty.
    Galaxy Nexus ? 2
  10. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I went out and looked at mine last night with the measuring string. It's not just the steering wheel that is off. The steering wheel has a very slight tilt left. What exasperates this is that the seat has a slight tilt to the right. The right of the steering wheel sticks out less than an inch farther than the left. The left front of the seat sticks out ~half an inch farther than the right. The weird part was that the seat back was the opposite. The bolsters on the right side of the seat back stuck out about an inch farther than the left... Not sure why they did this, but it brings a twisting motion to my mind just looking at it. As an FYI, I have my seat in the middle of just about every setting, so this may be worse in other locations. My steering wheel is all the way down, as well.
    I hate that you showed this to me... it won't be an issue for me, but now I know it's there. :LOL:
    minkus likes this.
  11. R Scneider
    R Scneider Member
    86
    37
    All I know is the drivers seat is a lot more comfortable than a bunch of other sub compacts I have driven. I don't care if its not square to the wheel IMO.
    ftl and ztanos like this.
  12. Nel
    Nel Member
    174
    84
    SF Bay Area
    Ztanos.... Should've left it alone if it didn't bother you. Now you have a little thorn in your side every time you think about it :oops:
    BTW my hubcaps are hideous. Just throwing that out there
    Galaxy Nexus ? 2
    ztanos likes this.
