Cheap Front Splitter / Lip
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Agent J, Jun 3, 2013.
  1. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Got lip? :p
    Since it was cheap as chips, I decided to try it on and see how it would look and function.
    It definitely made the car look lower and though it always rubs on my otherwise non-steep driveway, it is made of medium soft rubber and therefore is able to bend. You won't even hear or feel it scraping. Functionality-wise, I haven't really felt a difference in MPG yet as it started to get colder here and therefore been seeing expected losses in MPG already. Though i kind of felt my glides on my usual route went a bit longer or the speed dropped slower than normal. Not entirely sure. Haven't done some highway miles on this either. The only thing I'd recommend is to reinforce it with screw fasteners or clips from the underside as it is only held by double sided tape. I've temporarily used some medium-sized binder clips you'd use in documents and seems to be holding on.
    Bought it from ebay
    ZFL, syc, Prius408 and 2 others like this.
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Looks great! I might try in on my v!
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Not bad at all! and super cheap!!
    Daves09prius likes this.
  4. Agent J
    294
    111
    Sydney, Australia
    Still contemplating if i'd go for the side skirts as well... :D
  5. DarkPri503
    DarkPri503 Junior Member
    68
    Salem
    This looks really really sporty. Love it!
  6. Sezy
    Sezy Active Member
    439
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    I did this on my 06 Acura TL twice after the first one developed a small tear and love how it looks. It's a rubber or foam liner used to keep water or weather out from the bottom of a garage door. Dubbed "HD lip" for Home Depot since you buy it there for like $10 compared to those scammers on Ebay selling it for $50+. Almost did this last week to our new prius but my girl said it may look tacky. Compromised and said lets look in the daylight. When time and weather permits I'll do take many pics and get this on my white prius. This month for sure.
    ZFL and Daves09prius like this.
  7. drew935
    drew935 Member
    168
    Nor Cal
    I did this lip install about 10 days ago.
    Here's one with and one without that parked behind.
    Upclose:
    NortTexSalv04Prius and Agent J like this.
  8. Agent J
    294
    111
    Sydney, Australia
    i like how you removed the original small lip, which gives the splitter more surface area to cling onto. It looks good too!
  9. drew935
    drew935 Member
    168
    Nor Cal
    Thanks!
    Actually, the small lip is still there and yes hidden.
  10. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    I purchased some of this material (frost king garage door seal hammer on wit nails) and double stick tape....the lip splitter/lip mod looks okay the one you have posted. Sadly on my vehicle the lower lip is damaged on the right side of vehicle. To fix would require replace....I have been playing around with this material and seems to make a nice fit for upper grill block.
  11. Sezy
    Sezy Active Member
    439
    229
    37
    2020 Prius Prime
    Looks good and nice visors. I started to put mine on but got distracted by house projects. When holding mine up to the bumper I wondered if I should cut the lip when the bumper starts to corner. Basically have it the length of the lower grill and taper it off in a way. On my TL I did a lip twice. First time it was all the way across and kinda looked funny on the corners. Last time I did it, we cut it where the bumper curves and looks so much better. Thoughts on doing a full length lip VS a lip only covering area below the grill?
    Quick reference pic of how my lip is now on my TL. Please don't need comments on the red paint, I plan on blacking it out when I can afford a new paint job. 20130821_115840.jpg
  12. drew935
    drew935 Member
    168
    Nor Cal
  13. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    Looks good! I did this to my previous car, a '00 Olds Alero, and it was perfect. Super easy, 10 min install and looked great. I considered doing this to the Prius, but wasn't sure since the bottom of the front bumper cover is not flat. Still, looks like you worked around it easily enough. For $15, I'll give it a go this weekend.
  14. drew935
    drew935 Member
    168
    Nor Cal
    It takes a little bit of patience. I did fasten the edges where it contours and also with the plastic trim bolts since it runs through the path of where it mounts on the bumper.
    Here's another view:
  15. Sezy
    Sezy Active Member
    439
    229
    37
    2020 Prius Prime
    Used self tapping short screws on some edges and clamped it over night for better hold on the tape. This is my fiance' and my car (title is in both names) but she drives it mostly. She thinks it's ugly and wants it off. Claims people ask "is that a factory defect?" and it does nothing for the car with no benefits. My friends and I really like it. KEEP or LOSE it?
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Keep it!
    Prius I.T. Pro likes this.
  17. drew935
    drew935 Member
    168
    Nor Cal
    Keep it. It gives the car a little more attitude (y)
  18. Prius I.T. Pro
    Prius I.T. Pro New Member
    McKinney, TX
    Looks really cool, I like it.
  19. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    you should sticker bomb it!
  20. Sezy
    Sezy Active Member
    439
    229
    37
    2020 Prius Prime
    Was thinking just for fun sharpie graffiti one day. ;)
