HELP!!!!!
Discussion in 'Gen 2 Prius Main Forum' started by Mike Brown, Jun 5, 2013.
  1. Mike Brown
    Mike Brown New Member
    Not very car service oriented.....but changed my own spark plugs tonight. Now, check engine light is on and engine will not accelerate. Please help.....my wife leaves for work in 7 hour and I gotta get this car back running if at all possible! Thanks!
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Double check that the igniters are in place, all the way, tight, and that the wires are in the proper sequence.
  3. Mike Brown
    Replaced 1 plug at a time so no issues with plug wire placement.....have no idea what an igniter is .
  4. Mike Brown
    tried to be careful that each plug was about as tight as when I removed the old one, also made sure plug wire went on each plug and then tightened the bolts that hold the plug wire in place.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Ignition coil?
    I've never personally done the working of changing the plugs myself on any car I've had (left it to others) and mine's not due for while. But, I'd use a torque wrench and follow the recommend amount of torque instead of guessing.
    However, I'm not sure that's the cause of your probs. Hopefully one of the repair experts will chime in.
  6. matt b.
    matt b. Member
    251
    60
    L.A.
    obviously the salesman that you bought the car from didn't tell you what mine told me that everything I knew about regular cars throw that out the window this is a whole different beast you shouldn't try to change those yourself
  7. matt b.
    matt b. Member
    251
    60
    L.A.
    Trust only toyota service !!
    I wouldn't trust a family member with 20 years experience to work on this kind of car. and as for the seven hours you might as well get a rent a car or take her to work and then get that car towed to Toyota and have it done correctly
  8. matt b.
    matt b. Member
    251
    60
    L.A.
    Good luck though, don't mean to be such a downer.:)
  9. Mike Brown
    Thanks all.....disconnected/reconnected Negative cable on battery in trunk. fixed problem.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Mike, the igniter is the device that sits on top of the plugs. They are pictured below.
    Also, I know this is late in the game but you might like to review this thread. It might give you an idea of what to check. You never did say what brand of plug and type you used. I have not done this job, however the author of the link below has and is very knowledgeable when it comes to the Prius.
    Spark plug replacement - tools needed | PriusChat
    Good luck to you and I hope this helps you.
    Ron
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Seriously Matt, most of the engine related stuff on the Prius is no different to any other modern car. Simple things like replacing spark plugs or changing engine oil are in no way "special" on a Prius compared to any other car.
    Mike: Unplug and then re-plug all the igniter connections (the low tension wires to the top of each plug).
    BTW. Did you disconnect each igniter before you removed them? Some people disconnect them all, while others find there's enough slack in the wiring harness to remove plugs #1 through to #3 without disconnecting the wires, and only disconnect #4. Hopefully you didn't try to remove #4 without disconnecting the igniter as you may have put too much strain on the wiring harness and broke something.
    BTW. The toque setting on the plugs is only 13 ft-lbs.
  12. nh7o
    1,686
    340
    Hawaii
    This site would not exist if those who frequent here believed that. The light of knowledge will make the "beast" shrink into just another vehicle, with quirks and preferred techniques, yet quite fixable by DIY'ers. The dealers love to see customers queue up for their inflated service charges, so they use fear tactics, and that sadly works well too often.
