New GenIII brake recall affects 87,000 cars
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DavidA, Jun 5, 2013.
  1. DavidA
    2,345
    1,821
    Chicago western burbs
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  3. bwilson4web
    16,299
    One of the problems with being an early adopter of a model-year change, infantile problems. We had the 'brake-pause' recall, fixed by a software patch. Now it appears there is a mechanically weak part, the accumulator. These are not related but reflect what happens when a new design shows up . . . often service is reveals problems not otherwise known. It just comes with the territory.
    If you want stability, a well-debugged car, buy the last model-year. By then almost all of the early problems have been found, fixed and built-in at the factory to the car.
    snead_c and Feri like this.
  4. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    WOO HOO!
    I'm not part of this recall!
  5. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    This is a new recall, today, June 5, 2013. There's already a notice on my Toyota Owners portal that my vehicle is part of the recall (Prius # 59000).
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I am part of this recall also. The CNN.com article indicated that the recall was due to owners complaining about having to press harder on the brakes than normal. I have not had this problem but, after hearing the high cost of replacing the brake accumulator parts, I am glad to hear that Toyota appears to be addressing this problem.
  7. godzillaismad
    godzillaismad Member
    199
    94
    Does this recall apply to international customers or just the lucky US customers only??
  8. Jared
    Jared Member
    209
    Long Island
    I've already had the brake actuator replaced (under the extended warranty). I don't know if my Prius is affected. It is a 2010 Prius.
    In general I have noticed that the brakes on my 2010 Prius are just not as strong as on my 2005. It's the only weakness of the car, but it is irritating. I wish they had stayed with the gen 2 braking system.
    HGS likes this.
  9. hill
    8,877
    I marvel at the rationa
    Toyota lets some things go, and other things, like this brake issue, they get on it much quicker. I marvel at the rational how one thing that's prone to fail gets put off for years, while the next thing gets done much quicker. We got put off for our inverter cooling for a long time ... while the MFD failures got recalled pretty quick. The brake-pause was stalled for a good amount of time ... but this brake issue ... boom. Much quicker. It's a mystery.
  10. jdcollins5
    5,131
    1,346
    Wilmington, NC
    On the Toyota Owner's website under the FAQ section they list 82,000 US owners with build dates between March 2009 and early October 2009. My build date is July 2009.
    The article stated that the majority of the cars were in Japan.
    spiderman likes this.
  11. Blu-ray
    471
    198
    TampaBay, FL
    I have the 2012 and the brakes aren't like that. I had to emergency brake about a week ago and thought I was going to go through the windshield it stop so quickly. I was doing 60 at the time and went to zero in no time. The car behind me swerved off the road (THANKFULLY!) so I didn't get rear ended. Luckily no vehicles were damaged, I did however have to change my shorts afterwords and buy an air freshener.
    Robert Holt and PLSPUSH like this.
  12. Jared
    Jared Member
    209
    Long Island
    When I have had to emergency brake, the car does stop quickly. But under normal braking it is not as strong as the 2005 Prius, which has the best brakes I've ever experienced. Odd, since the gen 3 car has 4 wheel disc brakes.
  13. Blu-ray
    471
    198
    TampaBay, FL
    Hmmmm... well that's strange, because for the first few weeks of driving my 2012 I had to keep reminding myself not to press too hard on the brakes so I wouldn't end up stopping way to short.
  14. nparker13
    nparker13 Member
    121
    CT
    I believe this is linked to The $3000 Brake Job | PriusChat I had the exact same problem, and the dealer has been installing a new accumulator / master cylinder since last week.... great timing!!
  15. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Looks like mine is affected... guess I'll wait for the letter.
  16. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    If you go to the Reuters story linked in cwerdna's post above, you will see that international customers are included.
    The 242K cars in the Reuters headline include those recalled worldwide (I think), and the 87K number in other headlines appears to be US numbers.
    BTW, what exactly IS a brake pressure accumulator?
  17. burstaneurysm
    469
    144
    Chicago, IL
    going red baby! and xpcman like this.
  18. kgall
    kgall Active Member
    984
    152
    Yep, my momma always told me not to buy the first year of a new model car. This is the first time I've broken that commandment.
    Yes, based on dates of production it looks like my car is included.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    mine is covered too!
    jdcollins5 likes this.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    your momma?
