iPhone 5 and USB?
Discussion in 'Gen 3 Prius Audio and Electronics' started by bjdrums, May 13, 2013.
  1. bjdrums
    bjdrums Junior Member
    Temecula, California
    I can't seem to get my iPhone 5 to play through USB. It works fine when streaming via Bluetooth (and will charge off the USB cable).
    However, when trying to run audio through the USB cable, it'll only play for a few seconds then stop with an error message like "Problem with the File Format" or "No recognizable files."
    I'm also using Spotify and the built-in Podcasts app for audio. I don't have any music preinstalled on the Music app.
    Any help would be appreciated!
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I have iPhone 4S but play music through Bluetooth.
  3. bjdrums
    Yeah, BT is no problem. Just wish I could play over USB. Might be an issue with the new Lightning connector they introduced with the iPhone 5.
  4. bathala
    bathala Member
    128
    30
    Area 52
    I'm using iPhone5 with USB - no problem here.
    JMD likes this.
  5. bjdrums
    Hmm... Wonder what I'm doing wrong.
  6. bathala
    bathala Member
    128
    30
    Area 52
    Process of elimination. Have you tried playing music through the Music App? It could be the other apps you're using are the problem. If you still get the same issue with the Music App, try replacing your USB sync cable. Keep trying other possible causes. It could be the iPhone itself (just guessing...). Try an ipod.
    JMD likes this.
  7. DU3L NRG
    DU3L NRG Junior Member
    37
    My iphone 5 works fine, must be an app that you are using or something in settings. Try to reset your phone and play with the standard music app before starting up any other apps, if that doesnt work get ahold of apple support.
  8. David Watson
    David Watson New Member
    St. Louis, MO
    afaik, you can only play certain apps via USB, music, Pandora, etc. is there a reason you don't want to use BT?
  9. bjdrums
    Bluetooth can be choppy sometimes and I feel that the quality of the USB audio is better.
  10. JMD
    3,779
    1,282
    I'd follow Bathala's advice. Sounds good.
  11. bjdrums
    Yeah. It looks as if it boils down to an app compatibility issue. Got it to play and navigate tracks from the music app and then Pandora, but it doesn't seem to like Spotify.
    Once I launched Spotify, it went back to its expected symptoms of stopping after several seconds. Not only that but I couldn't get it to sync up with the music app again unless I unplugged/reconnected the USB cable.
    That's too bad since I really prefer Spotify over anything else. Guess I'll just stick to Bluetooth streaming until there's an update with the hardware or software that fixes this problem.
    JMD likes this.
  12. eastval1
    eastval1 New Member
    I was having this same issue using Spotify via lightning cable. I found that if you hit the Airplay icon (the little TV looking icon on the song information screen in Spotify) and select 'dock connector' instead of 'car multimedia system' it works like a champ. Sound is definitely much better than it is with Bluetooth.
  13. calvin mcgill
    calvin mcgill Junior Member
    I have the same problem. I can play music fine (USB Cable) but when I play any podcast it starts to play then it just stops playing and resets. I have to reseat the connector but that hasen't corrected the problem. My wife was saying maybe it's the podcast is not downloaded from itunes, could be the problem. I'll have to try it again with a podcast from itunes. Stay tuned.
  14. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I have a different, though similar, problem. I can play Pandora or my music library through BT, but not the dock connector. I have tried different USB cables.
